overdriven crank pullies ?
Old Jan 28, 2010 | 08:18 PM
73 LS-4's Avatar
73 LS-4
Default overdriven crank pullies ?
Sorry guys, new to the FI world, so this might be a stupid question. I did a search on these and came up with mostly availability and how to pin them. Wondering the advantages and disadvantages of these, along with what modifications are needed to install one?
Pat Kunz
Old Jan 28, 2010 | 08:24 PM
bullitt4110's Avatar
bullitt4110
Advantage is more boost, more belt wrap around the crank pulley were most best slip occurs, if you dont want to up the boost you can run a larger top pulley for again more belt wrap. Not really any disadvantages that I can think of. To install it the steering rack need to be removed or slid to the side, then just remove the bolt and pulley and put the new pulley on, pin it, torque the new bolt down to spec and then put the rack back in.
Old Jan 28, 2010 | 08:31 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
We have them in stock if necessary, along with crank pinning kits.
Old Jan 29, 2010 | 05:39 AM
clif's Avatar
clif
St. Jude Donor '09-'10
I had the Innovator's West 10% Overdrive balancer installed on my car. it is a piece of work!
Off with the old:
On with the new!
Old Jan 29, 2010 | 07:22 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Don't know why nobody answered your question yet, but the advantage is this. First you must know that a smaller blower pulley is more susceptible to slipping on the belt due to less surface area. If you decide you want more boost, the other option is to get an overdrive pulley. The advantage is you can keep your upper pulley larger and also gain surface area on the crank side, which is the other end prone to slippage. Another advantage is that you will increase the speed of your water pump and alternator. The vehicle voltage will stay up when you come to a stop light. I too have the Innovators West O.D. pulley. A&A sells it for a great price.
They do have key slots broached in them for aftermarket cranks. For the stock crank, you can pin it.
Old Jan 29, 2010 | 08:56 AM
Chris@East Coast Supercharging's Avatar
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Very Well said
Old Jan 29, 2010 | 10:00 AM
Jutskin's Avatar
Jutskin
A flip drive will solve the potential slippage issue and allow you to use 2 belts without a strain on your accessory units like a real tight single belt.
Both overdrive balancer and flip drive is even better.
Decisions, decisions...$ & $.
Old Jan 29, 2010 | 01:01 PM
wilson34's Avatar
wilson34
ECS, it says on your site that the crank pulley works on both 6 and 8 rib applications, would there be any issues running it on a 6 rib setup with no wall to support the belt and allow it to ride up on to other ribs?
I only ask because I will be going 8 rib eventually and wouldn't mind doing this while I have the car apart in the front.
Old Jan 29, 2010 | 01:41 PM
BLOWNBLUEZ06
Think of it like a belt sander. There are no ribs on the drums of a belt sander, yet when everything is properly aligned and set up, the sanding belt never moves. Same here except you have ribs to help. Alignment is everything!
Old Jan 29, 2010 | 04:33 PM
wilson34's Avatar
wilson34
I just see how easy it is for the belt to start riding on setups and feel though it may still be able to ride on the balancer and move from rib to rib due to their being no wall on one side of the belt.
I am also running the flip drive, maybe I won't even need the balancer we will see.
Old Jan 29, 2010 | 08:20 PM
73 LS-4's Avatar
73 LS-4
Great post OK makes perfect sense to me now. Thanks guys for your responses. So many ways to increase power in these things.
Pat Kunz
To overdriven crank pullies ?
