Throttle Body?
Old Feb 1, 2010 | 09:58 PM
Z0SIKHS's Avatar
Z0SIKHS
Default Throttle Body?
Should i port the Throttle Body? Will i need a tune? Will it mess up my tune?
I have a 2001 Z06 with ram air intake, cutouts, descreened Mass air flow, SLP 25% underdrive pulley and the coolant bypass mod.
Old Feb 1, 2010 | 11:11 PM
robert miller's Avatar
robert miller
Shouldnt do any more than what you have done to it a this time. Would all work better if you had a GOOD TUNER to do it after you get all you are going to do to it.
Old Feb 1, 2010 | 11:21 PM
Brandon619's Avatar
Brandon619
Yes, No, No. Are you running a stock intake manifold? What are your future plans for the car, i.e. road racing, drag racing, street driving? The reason I ask is because if you are going to add a cam, heads and a manifold I would hold off on the porting until then.
Old Feb 1, 2010 | 11:47 PM
Z0SIKHS's Avatar
Z0SIKHS
Well for now i just want to do little mods to make it as fast as possiable without having to tune it. Later in a few years i will drop a cam but for now i just want to be able to beat stock 02-04 vettes. Mine is an 01 z06 so i want to get more than the 405 hp, stock mine is 385 hp.
I just dnt want to make it to the point where I HAVE to tune it....i dont want to spend $$ on a tune when im going to spend $$ on a tune again when i drop the cam.
Remember that my car came with more restriction than the others, reason why it only has 385 and not 405....so with more air flow, i wonder if it will mess it up or mess the tune. Or can it handle it??
Is there any other things that i can do the the car to make it faster but not have to spend the major $$$$$????
THANK YOU EVERYONE
Old Feb 2, 2010 | 03:54 AM
QUIKSILVERZ's Avatar
QUIKSILVERZ
just installed a katech ported tb on my car a week ago. it is a 02z with long tubes, vararam, catback and a dyno tune. i am getting ready to install a ecs blower cam and have plans for a ecs novi kit down the road. with my future plans i figured the ported tb cld not hurt. i did notice a increase in throttle response but no seat of the pants change in power. even katech states ard 3hp increase for a similar car like mine. i did not need to have my car retuned and it is running great. BUT if i were you i would do long tubes first or sit down and think about what your long term goals are for YOUR car.
Old Feb 2, 2010 | 07:33 AM
Brandon619's Avatar
Brandon619
I'm an 01 Z06 also but I'm 418 cubic inches in a LS2 block.
Old Feb 3, 2010 | 05:55 PM
Z0SIKHS's Avatar
Z0SIKHS
Okay well if i take it off, do i need a new gasket?? Also, since it is electrical and not a wire drivin one, am i going to have to recalibrate anything? im sure the guy i take it to is going to end up moving the flap in it to clean it. will that throw of the tb sensor?? I just want to make sure before i take it off because i dont want i the not work after i put it on and then i have to spend more $$. Thanx
Old Feb 5, 2010 | 03:30 AM
Zosickness's Avatar
Zosickness
Don't need a new gasket. Don't need to recalibrate. Just be careful around the areas where the blade touches the body. Take too much off in that area and you'll need another tb.
To Throttle Body?
