97/98 Fuel System
Old Feb 1, 2010 | 10:09 PM
elite gm's Avatar
elite gm
Default 97/98 Fuel System
I have searched a found a few posts on what is needed here (particularly the one by quicksilver2002) but all the links are dead.
Can anyone post up here what parts I will need to convert my 01 Z fuel system to the 97/98 return at the rails system?
I already found the fuel rails, so I am guessing I will just need the return line (part#??? or custom line?) and fuel filter? What else?
Thanks!
Old Feb 1, 2010 | 10:51 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
If you can find a part out, get the line assembly as it has a check valve located right off the bucket assembly. I don't believe you can buy just the return line over the counter. You'll need the regulator if it's not on the rails, the braided line that's in the engine bay, and the filter.
Old Feb 2, 2010 | 07:20 AM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
This may help some, no part numbers but gives an idea of what is needed and options you can go with (the fuel system write-up).
http://www.robertsnitrousservice.com/n2otechnicalpapers.htm
Robert
To 97/98 Fuel System
