A&A Corvette Performance:Forced Induction Q&A thread
#221
CF Senior Moments Member
1 Post
oops
Just a question? How are you guys getting 550 plus to the rear wheels? I was told that I only got 480 to the rear. I am not complaining because I am happy with my A&A SUPER CHARGER and the installer. Those number sound inflated. What should I be getting? My car is an A4 and pretty much stock.
I realized after checking my old dyno sheet the motor is putting 557 max to rear wheels (not 590) :o
#223
Former Vendor
Location: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
Not sure what to get for the holidays? How about an A&A Corvette Gift Certificate?!
http://www.aacorvette.com/performanc...roducts_id=342
#227
Some great info on this forum but still looking for a little help please!
I understand the differences between the V-2 and V-3 trim but what really are the pros and cons between both?
I have a stock (Borla cat back) very low miles 04' Z06, looking for the biggest bang I can get without motor work (aside from cams). need some help with ordering...
What trim?
What pulley size?
What cam?
Pete
What trim?
What pulley size?
What cam?
Pete
#228
Former Vendor
What trim?
What pulley size?
What cam?
Pete
What trim?
What pulley size?
What cam?
Pete
Si-Trim?, T-Trim?, YSi-Trim?:
•The Si-Trim is our standard unit and is recommended for all stock engines or engines with mild modifications only. (headers, camshaft, etc.) The Si-Trim is easily capable of 650 RWHP on a mildly modified engine. We see no reason to use a larger supercharger if your aspirations are 650 RWHP or less.
•The T-Trim is recommended for applications up to 750 RWHP. The T-Trim can utilize smaller pulleys and make more boost and power than the Si-Trim.
•The last model is the YSi-Trim. This model is a V-7 which is not self contained. It has straight cut gears and is louder than the V-2 and V-3 units. The YSi is for extremely high output applications and is not recommended for engines with stock pistons.
V-2?, V-3?:
•The Si and T-Trims are available in two different models. The V-2 Si and V-2 T-Trim superchargers are lubricated with pressurized engine oil. No oil changes will be necessary. Each V-2 kit is supplied with a supply line and fitting, a return line and a special tool to cut a clean hole in the oil pan. The Corvette oil pan is aluminum and of sufficient thickness to allow threads to be tapped in the wall to seal the return fitting. There is no danger of oil leaks if installed according to our instructions.
•The V-3 Si and V-3 T-Trims are basically the same units but are self contained. Each has a sump, holding 4 oz. of supercharger oil and do not require and oil feed or return lines. You will need to change the oil in the supercharger periodically, however. Fortunately the V-3 head units have a convenient drain line attached to the bottom of each unit. This makes oil changes very simple. Both V-2 and V-3 models have helical cut gears and are considered to be very quiet.
On the LS6, we run the 3.8 pulley, which will be around 8psi. That is the level we feel safe with. If you want more boost pressure, go with a smaller pulley. If you want less boost pressure, go with a larger pulley.
Cams are harder to nail down in a paragraph. But, for a LS6 we would run somewhere around a 220-228 with a 116+3 LSA.
#229
Here's some info on the superchargers:
V-2?, V-3?:
V-2?, V-3?:
Thank you...
What are the pros/cons going with a T trim vr a SI and a V2 vr V3?
#230
I ran into a small problem with my new Procharger bracket when installing with the Innovators West 8-rib pulley. I ended up having to grind down the small plateau on the spring tensioner (raised area w/ arrow) because it was contacting the face of the IW pulley. The pulley is definitely 100% seated. Has anyone run into this before? Not a big deal...it was quickly fixed, but maybe I'll save someone a headache in the future. Thankfully I caught it before starting the car.
#231
Former Vendor
When you mounted the tensioner back on the bracket, did you take the washers off between the tensioner and the bracket and use the smaller 3/8-16 x 1 3/4" bolts?
#232
Thanks for the reply Steve. I actually did not disassemble the unit to grind down the tensioner. I have about .125" clearance now. Would removing the the washers gain much clearance? Also, were the smaller bolts included somewhere or do I need to pick them up at the hardware store? I didn't see extra hardware in any of my shipments, but I can double-check.
#233
Former Vendor
#234
St. Jude Donor '08-'09
Steve,
I have emailed a few times on the build im in the middle of, but i need more information.
I have decided to have a 396 stroker w/9.5:1 built instead of the 383. Went for the whole enchilada...
Based on this being the only change from what i emailed you about, what pulley would i need to order from you with the V3S1 kit to get me in the 600-650rwhp area? You had stated that with the 383 that to get 550-600rwhp, the basic system would be fine and i could pulley up from there.
Now with this cuin change, what would you suggest. Also, you didnt give me the part number for the cam shaft to use that is under 600 lift.
#237
CF "Young" Senior Member
Hey A&A, just a heads up, you may want to double check your wiring documentation for installing the gauges in a C5. I've got an '01 A4 'vert, and ended up finding out that the *brown* wire, not the purple one, on my trunk release / fog light switch wiring was the switched power source for the gauge lights.
This isn't the first time I've had an issue like this with my car; a while back I did a stereo install on it and a particular power-antenna wire that everyone else had didn't exist in my car. I'm not sure which part of the '01 A4 'vert aspect of my ride affected this change in the wiring, but I just had a big headache sorting that out.
All being well, I'm taking it in to be supercharged tomorrow, can't wait!
#238
Former Vendor
Steve,
#239
Former Vendor
#240
Talked with one of the mechanics at the shop about how he installs the wiring normally, he suggested working off of the dimmer switch. A miscommunication between the shop owner and I meant that the supercharger's not being installed til next week (turns out the kit hadn't even arrived yet and I thought it had), so I'm gonna let the car sit and see if it drains again. If it does, I'll start trying to diagnose the source of the problem since I've got a few extra days to deal with it.
