Hey guys. I am needing to purchase some new injectors. This is for a C5 402 F1A Z06 auto. When I built the car several years ago we had a goal of 800rw. Car made 850 at 13 psi. He now wants to turn it up and the 60lb injectors are maxed out. I am looking for a injector that will get us to 1000rw safe. I would also like a injector that someone has good IFR data on. I would like to be able to swap injector and change the IFR table and be some what close. I am not looking to do a total re tune if possible.
The Seimens Deka IV Mototron 83lb injectors with the EV1 USCAR connectors might get you there and has all the good injector data on them.
The only high impedance injector (with data) above that is the 1000CC Bosch injectors. Taylor at Dallas Performance sells them and paid for independent testing on them because using the existing data was causing him problems. I am running these injectors and love them. http://injectordynamics.com/
Kris, give me a shout. I've got a few things for you. Plus if necessasy, Ive got some 96lb injectors, with an AEM driver box I can sell you for less than those modified injectors.
If you want some 80's, ive got them for less than 400 bucks, and ive got the factory data to boot
