aps twin turbo oil leak question
I had a small oil leak from the oil distribution block. Forgot to use thread sealant. So I pulled it all apart and fixed it. After I pulled both the lines that feed the oil to the turbo's off I got under the car and noticed oil dripping from both turbo's were the wastegate pipes bolt on. I know I used the wrong sealant when I installed them but have them off now to correct that problem. I started the car, made sure the oil scavange pump was squirting back into the valve cover, it was, and once the oil burnt up it seemed to stop leaking. I asked the shop where I bought them because I was worried about a bad seal and he said it doesnt quite work like that. Can anyone put my mind at ease and explain what happened. I only put maybe 100 miles on the car sinse the installation and now there is literally 3 feet of snow here. Plus I want to know if I need to fix something before reassembly. Thanks for any advice. Everyone has always been helpfull.
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
I Believe In The Beer Fairy
Could very easily be bad seals. Did the car spend any time on jack stands or did you have the manifolds off with the turbo's tilted backwards??? Mine will leak if tilted down at all.
Another thought.....you disconnected the lines, bypassing the sealed system for the turbo feed.....that distribution block is designed to keep oil from flowing when there's no power. Could be that what was in the lines drained into the turbo's, filled and went past the seals, and once you buttoned and burned it off everything was fine again.
I'm working on getting my aps tt going also. I don't have it on the road yet and my passenger side turbo is leaking like you said yours is and then it smokes like a freight train for a while. I sent this guy on ls1tech named Louis a PM about rebuilding the turbos. Here is his response:
They dont usually fail that soon. how many miles are on it?
Double check your scavenge pump, and make sure you have a GOOD crank case breather. I have a car here that is on the stock motor, stock twins, made 570/570 on pump, no meth, strait wastegates.
It started smoking and leaking. I tore it apart, turbos were fine, but what we found was that the scavenge pump needed to run for a period of time AFTER the engine was off. We built a timer for it that ran the pump for 10 seconds, as there was 8 ounces of oil in the center housing prior to the pump staying on, and we reduced that to 2 ounces.
THAT much oil, 8oz, seeps thru to the turbine, and leaks like a siv. It will not smoke on start up because there is no heat. First time you romp on it, huge cloud.
The turbos are most likely fine. I would try the pump solution first, then we can talk about turbos.
Louis
Louis
Louis
Louis
I asked about the timer but didn't get an anser yet. Right now I just put a toggle switch on mine to see if running it after shutdown and a little before start up would help. So far, it don't seem to help the smoking on mine. I haven't had time to research the timer relay yet.
St. Jude Donor '08
Is the smoking different now that you have the TurboWerx pump? Did you have a smoking issue before. Mine is terrible. It does clear up once in a while.
Pro Mechanic
My scavenge pump bit it, turbowerx cured my smoking.
Chris, isn't the pump wired to be on when the key is on?? I think mine is, so if that's the case, just leave the car in acc as you're preparing to exit and you should be fine.
I believe it is wired to come on once there is oil pressure.
St. Jude Donor '08
The turbowerx cured all my smoking issues, but it still spits out oil upon startup. I'm pretty sure the pump is wired through the fuel pump relay. Now how it works through the relay, I'm not sure.
Did you buy the pump from tubowerx or is there a vendor that carries them? I saw it for $349 on their website.
