So what defines a "blower cam"?? I realize its a cam optimized to work with forced induction, but what about the grind makes it ideal for these applications? The cam ive got in my car right now is 230/232 592/595 111 lsa. Being that it wasnt advertised as said "blower cam", Im assuming that its not ideal for a forced induction application and therefore I might be leaving some power on the table, but is it really something that would need to be changed in order to run a mild forced induction set up at 6.5lbs of boost or so?? Just wondering if by installing the cam a few years back I inadvertantly precluded myself from ever going FI without changing the cam again.
There are plenty of opinions here on that. Every setup is different, I am not sure anyone has had such a large (small LSA numerically) cam that didn't make good power.. Actually one that I can think of was a guy running a KB i believe that had an LSA of 108 if I recall. I believe we all agreed that a tighter LSA would have upped the power tremendously.
Anyone else think of more?
Thanks for the help!
Trick question I would say. Don't get stuck on the whole "blower cam" name. Just get a cam that works for your setup.
Originally Posted by C5kid
usually a wide LSA makes it a blower cam. There will be less valve over lap, thus less bleeding off of the boost.
if that was on a 115 lsa that would be a great cam for a S/C
A wide LSA just gives you a broader powerband as opposed to a peaky powerband. Not necessarily a "blower cam". Yes, there is usually less overlap.
Originally Posted by FLYNAVY30
ok, that makes sense, so will the cam Ive got work ok on a lower boost application or is it not worth doing without changing the cam?
Your cam will do fine for your boost setting and I wouldn't worry about changing it.
That was probably me. I had a 248/254 .622/.622 on a 108 LSA with my Kenne Bell. I was losing about 5 psi of boost, but I still made 626 hp with my Setup.
Had to be I couldn't remember the power it put down but I knew it was still plenty
I borrow this thread to this question:
So called "blower cams" ad 30-50 hp to basic blown LS1 combo, right?
How much do I get with LS6 cam?
How much with any N/A "big cam"?
Is it worth the money to get a "blower cam" if the engine is otherwise stock (except for blower and some bolt on's)? Do I gain 10 hp over LS6 cam or much more?
