Checking an engine prior to going FI
Old Feb 16, 2010 | 11:25 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Default Checking an engine prior to going FI
Other than a standard compression test, is there any way to check out an older engine to see how strong it it for taking boost? My 97 130K LS1 hasn't displayed any problems since I've had it, but I'd like to have a little more confidence in my engine. before i go and throw a supercharger at it.
Old Feb 17, 2010 | 07:08 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Another test to run is leakdown. This will pressurize the cylinder with the valves closed and measure leakage as a %. Even if the leakdown test shows a good cylinder seal, the weak link in the engine is the ring lands. That won't show itself until it's too late. Do the leakdown and then try enjoying low boost on a conservative tune. ~550rwhp is a reasonable goal where you won't suffer from reliability concerns so much. Tuning is the key. I would rather more boost on a conservative tune than less boost on an aggressive one.
Old Feb 17, 2010 | 09:21 AM
396375's Avatar
396375
St. Jude Donor '08-'09
Sell it while it's still running good and buy a forged motor.You know you're going to do it anyway .
Good luck.
Old Feb 17, 2010 | 09:46 AM
Slow Z06's Avatar
Slow Z06
Leak down test. Compression test. Reality test is the biggest one.
Be real with what you want to achieve then up the goal to the next level. if you still think the motor and other supporting parts are still within that goal, go for it.
Quote (Brett): "I would rather more boost on a conservative tune than less boost on an aggressive one."
True story!!!
Old Feb 17, 2010 | 10:13 AM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
My goals exactly. I'm not shooting for peak numbers by any means nor is my car likely to see a dragstrip. It's a daily driver that i just want more power at crusing/highway speed when i need it.
Aside from price, is there any downside to FI?
Old Feb 17, 2010 | 10:51 AM
Slow Z06's Avatar
Slow Z06
wanting more as soon as you ride with someone that has more
its a shady path once you start it....LOL
Old Feb 17, 2010 | 11:25 AM
JustinStrife's Avatar
JustinStrife
Supercharged this motor at 107k miles. She currently has 124k with no issues. Original clutch too!
Old Feb 17, 2010 | 12:36 PM
wilson34's Avatar
wilson34
Well the only downside is breaking sh*t, but that only gives you an excuse to go bigger
To Checking an engine prior to going FI
