2001 Fuel Filter Mod
I have a 383 with a Procharger. Making about 600hp but running out of gas with a Racetronix and BAP.
I was briefly told that I could mod the existing fuel filter?? or use 97-98 parts to do something to help (but didn't get all the specifics at the time)
Can anyone expain the filter mod?
So,... I think you have a problem somewhere. Possibly clogged filter? Is the pump done?
I was told that I need to change the fuel rails too since the 60's are sucking the stock ones dry so that's next on the list.
Filters play a big part in delivery. I work as a tech at a dealership,....you wouldn't believe some of the stuff that comes out of these things. It's cheap enough to replace every few thousand miles.
I did leave out that I run FAST fuel rails with that setup. Good idea that you have to replace them with larger units. Any brand would work of your choice.
After that, you SHOULD be good to go, as long as your pump is still golden. I think racetronix rated those pumps to 700 something,... I think they were dead on from my experience. With a BAP, i'd probably think you could net some more but, I honestly do like relying on BAPS as I have seen several fail through the years here with some cars,... although I have seen SOME last years as well.
Hope the filter fixes the problem man. May want to put a gauge on the rail and go and test the pump out. YOu can always test fuel pump volume by installing a mechanical fuel gaue(for testing-not like an autometer or something).... one with a pressure relief button,..... start the car.... then, with a drain bucket(waterbottle-long hose, whatever), while the vehicle is running, you can press the pressure relief button, and see if the car dies,....stumble,..etc. If it does stall,.... you have a GOOD PRESSURE but NOT enough volume. Meaning an obstruction(clogged filter), and or a bad pump.
Again.... hope it's a simple filter issue.
*on 42lbers,fast rails, racetronix kit, hotwire, procharger, the same pump easily supported 615rwhp with no issues as well. So again, I think the number your looking for, your setup should work without issues.
your cheapest route is to change to a 97-98 fuel filter, add a regulator to your rails and install a return line. Check with A& A or ECS, I bet one of them can sell you a kit to do just this.
You will notice 2 plastic lines going into your current fuel filter. One being the main feed line and the other returning to the tank. Simply take the current filter off, mount the older style fuel filter and attach the main feed line to the filter. Disconnect the factor return line from the fuel hat as this is where I connected my return line from the regulator at the rails. I simply left the short factory line in place as it is sandwhiched between the frame rails and the body, so its not hurting anything. I am also still using stock LS2 fuel rails.
You can see here where the return barb is placed, however, I have since switched to an AN style fitting to avoid kinks, etc..
I vote for the 97/8 setup, you will always be looking over your shoulder running the regulator at the filter - just too easy to starve the engine for fuel.
As for hoping the filter will solve your problem - i wouldnt put too much faith on that - i used to change mine out every 6 months or so - and at ~80 a pop, that adds up. (i daily drove the car, so every 6k or so)
I had issues supporting ~500hp with just an intank pump and hotwire kit. Wasnt until i switch to the 97/8 that all my fuel issues went away.
Good luck.
Good luck.
Interesting how you guys have trouble at 500rwhp, and I didn't see trouble till 200+more rwhp then that. Odd,....wouldn't you think? (00 FRC)
I've since gone to a magnafuel xl750 -10 feed, -8 return, custom hat, 160lbers, and a magnafuel regulator.
There are folks out there pushing big power through the 97/8 system. I dont think it is a waste by any means - and is very reasonable compared to a full fledged racing fuel system.
Not disagreein' hommie. For the price, I agree.
