Newbee FI questions
Old Feb 22, 2010 | 01:41 PM
KenShores's Avatar
KenShores
Default Newbee FI questions
I'm thinking of getting the A&A SiTrim kit and was talking to an installer to do the job. Along the way questions came up about other mods, ie. headers, cam yada yada.
It was suggested (and why not) to get headers as the engine compartment will run hotter with stock exhaust. Reading other threads on headers makes the passenger compartment run hotter. Well no good deed goes unpunished.
I don't need gazzilion HPs right now. Up to 500 is fine with me and it would not hurt my ego any to run 422-450 for awhile. I'm just looking for the best bang for the buck. IF I get bored I'm sure I can save my bread and get more.
I'm more concerned about breaking trany's or rears, although I don't think I'll be doing burn-outs everyday.
So any good advice about the header thing? Trans? Rear? If I go with a $6500 mod for HPs and then what another $6k for comfort/ breakage protection? Then maybe I need to save some more shekels. But I got the bug and want to get started before the whole process looks like a money pit.
Old Feb 22, 2010 | 01:51 PM
M_T_0's Avatar
M_T_0
FWIW and IMO
the lt's and heads could come later if it were my money I would do a cam and upgrade the oil pump while installing the SC (and an overdrive crank pulley) if you think you will want these things (i would do the upgraded pulley reguardless). those are the hard parts to get back to later that will have to be exposed (or partly) while pinning the crank for the sc (and they are tuff to get back to later). as far as hp you can make as much hp as your stock short block will deal with just by turning up the boost on just about any Centri system so no additional upgrades needed.
Old Feb 22, 2010 | 02:13 PM
KenShores's Avatar
KenShores
Thanks for insight. Makes good sense on the crank/pully decisions. If something goes wrong over the years I'd change and make other mods, but I'm not really looking for the screamer. Easy and sensible bolt on HPs for my DD with a bit of room to grow if I get the bug even worse.
Old Feb 22, 2010 | 02:32 PM
Warp Factor's Avatar
Warp Factor
That's the first I've heard about the engine compartment being hotter with stock exhaust.....
Old Feb 22, 2010 | 03:52 PM
KenShores's Avatar
KenShores
Thanks me too
Old Feb 22, 2010 | 08:12 PM
Vega$Vette's Avatar
Vega$Vette
Thanks me too
Me three
I would do headers before a cam. When you do a Centri install you pin the crank. That's all you do up front so your not really saving anything by doing a cam now. Plus if you do a cam you better do springs.
The LT's now with the blower install is the way to go.
Old Feb 22, 2010 | 08:21 PM
clemsondave's Avatar
clemsondave
Stick or Auto?
For your goal, I'd do:
A&A kit
headers
boost-a-pump for the fuel
42 or 60# injectors
That should get you an easy 550. For your goal, a cam is not needed. I have stock cam and over 650.
Rear
Replace one or both output shafts
Stick?
Twin disc clutch (McLeod or RPS)
Auto?
dunno....
Old Feb 22, 2010 | 08:40 PM
KenShores's Avatar
KenShores
Thanks Auto trans and 3.15 gears. I've been kicking around doing an RPM V trans. This adds another 2400 + to the mods. This would be a sort of prevention mod but now begs for new TC, gears, yada yada yada mo money. This is DD with summer fun weekends. No doubt all could change but I don't see myself going to the track, cause itsa vert. So staying lower than 500 hp, 422.8 to 487.3 HPs is fine. But if I decide I need 517.4 HP I want to jump to it with restarting/replacing the mods again, and if I stay 466.7 thats fine too.
Thanks for all any any input. I want to stay with car for a long time (5 plus years) and once I get the HP jones fixed, Ill probably want new seats, stereo, more chrome stuff, yada yada.
Old Feb 22, 2010 | 08:56 PM
clemsondave
Ha! Good luck staying away from the track. See you at the Smackdown at MIR late in the year.
Old Feb 22, 2010 | 08:59 PM
Vega$Vette's Avatar
Vega$Vette
Unless you're going to track it with sticky tires your stock diff will hold up just fine.
I did 3.42s but kept the stock TC which I prefer over a high stall TC.
Old Feb 22, 2010 | 10:00 PM
KenShores's Avatar
KenShores
Thanks I need to hear this kind of thing. So far I'm liking the twisties more than the 1/4 mile. I used to drag race alot in my younger days, and breakage comes too easy. Back then I had nothing much else to do. Much of my concern is breakage with the added HPs and tourque. Want more fun without the repair bills.. I'm sure I could break it stock if I tried but that's not the goal. I just got the bug for mo power and FI seems to be the quick way (and less $$) to get there. Keep the advice comming, thanks. Giving up thr vette for a week will be bad enough to get the install and tune done.
What about multiple tunes? more, more better and maxed. can boost be programed or is it set by pullys?
Old Feb 22, 2010 | 10:20 PM
matt75's Avatar
matt75
If you do headers (lg, arh, kooks) and an s-trim aa package, 500rwhp is cake. drives like stock, same mpg except when you hit the boost.
Old Feb 23, 2010 | 07:26 AM
Warp Factor
If you think you'll eventually want a cam, MTO's advice is good about doing that while things are out of the way for the blower install.
Old Feb 23, 2010 | 08:13 AM
KenShores's Avatar
KenShores
Great thanks for the info. One goal is to try to keep the car a bit bullet proof. This is why I'm thinking about going RPM trans. While I wont be the wild-child everyday, I know that I can resist anything but temptation, and will let the boost loose. Trans is next mod and will not be able to install for some time. Any experience out there has far as the A4 trans holding up after SC? Would getting a in-line trans cooler save me for a while? I know my trans runs a bit hot during the summer sitting in traffic, and when traffic finally clears, well there is that temptation thing again.
Old Mar 4, 2010 | 04:45 PM
kh400's Avatar
kh400
Chuck Cow claims that the A-4 automatic will hold up to really high horsepower numbers if the correct tune is installed. Might be the way to go? Good luck!!!!!
Old Mar 4, 2010 | 11:26 PM
KenShores's Avatar
KenShores
Thanks for the info. It's good to hear as trying to play save with the trany makes costs go up. I have not had that many positive responses on the stocker A4, but a few. The tune has been stressed by the ones that have stayed the stock unit. Thanks
Old Mar 5, 2010 | 08:56 AM
gleds's Avatar
gleds
I made 494/468 with just a cat back, ported tb and air meter, and an a&a Si. My exhaust is stock all the way to the cat back. My car is a sleeper for sure.
To Newbee FI questions
Old Mar 5, 2010 | 09:53 AM
KenShores's Avatar
KenShores
Those look like good numbers to me. How is the trany holding up? Did you have any special tune done to it? I will also run stock exhaust. I also like the sleeper style. How much do you think the ported TB got you? I've been thinking of getting a polished TB to see if things increase on the stock motor, before the SC. I too am considering the A&A Si up grade. Thanks
Old Mar 5, 2010 | 11:25 AM
ctvette2003's Avatar
ctvette2003
You just think you will be happy with 500hp good luck with that
You might want to look into the definition of "Modaholic" as you're about to join the club and don't even know it.
Just remember these answers for your wife/girlfriend:
1: Yes dear i had to
2: I don't know what your talking about dear it alway sounded like that.
3: I had to change it the old one was about to break.
4: My mechanic said it was necessary or it wont run right.
I am sure the guys will be happy to continue the list
Old Mar 5, 2010 | 03:58 PM
KenShores's Avatar
KenShores
I think I can live with the 489.7 Hps but I haven't been there yet.
HP is probably like money the more you have the more you want - the less you have the more you want. It seems to be interchangeable ... in one direction anyway.
5: Gee honey I don't know where that $10K went, are you sure you didn't buy something?
6: It makes the car look so much better, don't ya think?
7: No, it's not faster than in used to be, I'm just starting to learn how to drive it.
