Vacuum Leak?
Old Feb 24, 2010 | 05:51 AM
tunedZ's Avatar
tunedZ
Default Vacuum Leak?
Ok so for the past few days I've been experiencing a very high pitched whine coming from the engine area, it only occurs at speed and not when I'm at a stop. I was looking over the motor today and I discovered that a hose had possibly blown off, I've attached a photo of where the inlet has no hose attached. What is this hose for and could this be causing the whine? Also, what is the best way to locate said hose and re attach? Thanks and sorry for the newbie question, I just want to get my baby fixed as fast as possible.
I drew a blue box around the area where the hose seems to have came off of....this isn't a photo of my setup just a similar setup to show where the hose flew off.
Old Feb 24, 2010 | 07:21 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Yes! that certainly will cause your High pitch whine - and it will pressurize under BOOST when you are getting on it - hence the clamp around it!
That one is used for pulling Crankcase pressure out of the motor and it will generally go to the Valve Cover - BUT under B@@ST it "NEEDS" a one-way check valve on it so it will not pressurize the crankcase -
Usually these are capped off and another source is used to pull the pressure away from the crankcase (Example - it can go to the intake tube before the SuperCharger) - make sure that anything going to the motor has a oneway check valve on it or it will not pull pressure away but pressurize the crankcase and blow out motor seals I know, it happened to me
Thanks,Matt
Old Feb 24, 2010 | 05:23 PM
tunedZ's Avatar
tunedZ
I can't seem to locate the hose, where does the other end connect to?
Old Feb 24, 2010 | 09:45 PM
frc00ny's Avatar
frc00ny
Not all installs use this hose. Some will have this pipe and the corresponding one on the valve cover blocked off with vacume caps. It all depends on the PCV system that your car came with.
Old Feb 25, 2010 | 12:42 AM
tunedZ's Avatar
tunedZ
its an 03 Z06 with the A&A kit standard pulley
Old Feb 25, 2010 | 12:43 AM
tunedZ's Avatar
tunedZ
I'm fairly positive the inlet was attached to a hose before.
Old Feb 25, 2010 | 12:48 AM
bullitt4110's Avatar
bullitt4110
The tube on the tb needs to be capped, along with the port on the valve cover. Get a cap for it and you'll be good to go.
Old Feb 25, 2010 | 05:33 AM
tunedZ's Avatar
tunedZ
where exactly is the port on the valve cover? thanks so much for the advice guys.
Also, is it bad for the motor to run with the tube on the tb uncapped like it is right now? the motor makes this high pitch whine/roaring sound at speed, I'm assuming that this leak has been causing it correct? I just want to play it super safe and be cautious, I've invested way too much $$ into my baby for anything to go wrong at this point.
thanks again for all the advice guys!
Old Feb 25, 2010 | 06:03 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
You have me wondering if the noise you are hearing is the bypass valve operating as it should. I don't have a turbosmart valve, so I can't tell you what it would sound like.
To Vacuum Leak?
