Fuel Pressure Reg. Adjustment
Can someone give me some basic pointers for adjusting a new fuel regulator installation (Prof Products rails and reg. with return).
I have a LS6 383, running 8-9 lbs boost, 60lb injectors, with racetronix and KB BAP.
Is there a specific pressure setting I need to start at?
Thanks!!
Thanks!!
remove boost ref/vac line, set the pressure at 58-60 psi at idle, reattach the vac line, get a tune
Some people will set the initial pressure a little lower, but the key is tuing at that pressure and do not change it after that.
Former Vendor
Location: FI Performance : Norwalk Connecticut www.FIPERFORMANCE.com
