Boost Compression Ratio
Old Feb 25, 2010 | 07:21 PM
user_name's Avatar
user_name
Default Boost Compression Ratio
When you run lots of boost keeping the heads planted on the deck seems to be a big concern. Some people I've talked to seem surprised that I do not push any water with stock heads, gaskets, and bolts at 17psi. I am getting ready to up it to 20psi which some people would think is just nuts.
I have some doubts about which factors are most key in keeping the heads down. I'm thinking that 20psi is not that much ASSUMING a cool combustion temp with no detonation.
Either way I wanted a way to roughly measure how much actual pressure was in the cylinder. After calculating it manually I found this online calculator.
http://www.rbracing-rsr.com/compression.htm
It looks like I'll be going from an effective comp ration of 22.64:1 to 24.79:1.
Has anyone has an lsx setup with a higher effective comp ratio? What was the setup, and what types of issues did you run into?
Old Feb 25, 2010 | 07:30 PM
Slow Z06's Avatar
Slow Z06
I got this:
Boost and Altitude Correction to Compression
You are running 20 PSI of boost at an altitude of 100 feet. Your motor's static compression is 9.5 :1. At this boost level and altitude your effective compression ratio is 22.41 :1, and without altitude correction your compression ratio would be 22.43 :1.
Old Feb 25, 2010 | 10:17 PM
Arun@ChampionMotors's Avatar
0Arun@ChampionMotors
Former Vendor
Based on the calculator I'll be going from 24.2:1 to 26.98:1 this season.
I don't forsee any problems other than faster trap speeds.
To Boost Compression Ratio
