supercharger!
Old Mar 14, 2010 | 01:57 PM
wagner262's Avatar
wagner262
Default supercharger!
so im getting a c5 in about a month but im thinking in about 6 months i want to put an a&a supercharger on it... nothing crazy just some extra hp!
so i have options
2003 80k z06
lower mile corvette
115k frc 2000
whats the best choice? do i have to worry about blowing a ring or piston? with certain milage cars? whats the best way to go about this?
Old Mar 14, 2010 | 02:02 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
so i have options
2003 80k z06
lower mile corvette
115k frc 2000
I would get the Z06, install the blower, a fuel system and methanol injection. Just dont get crazy on the boost and it will last a good long time.
Old Mar 14, 2010 | 02:11 PM
wagner262's Avatar
wagner262
with the z06 do i need to add a better clutch?
anything with the tranny?
im looking to go rediculous just 500 hp or a little more dont want to highly modify to much either
Old Mar 14, 2010 | 02:46 PM
JustinStrife's Avatar
JustinStrife
With the LS6 you'll hit 550rwhp easy with meth on low boost. With an LS1 you'll need either more boost or a cam probably.
I'd personally go for the Z06. Since you're hung up on that particular body style, might as well get the one that has the better rear diff, hotter heads/cam/intake manifold, oh and lower mileage.
Clutch, well it depends on how you drive it. I have almost 125k on my original Ls1 clutch. Been at 480-512rwhp for the past 18k miles(3 years). I don't race from a dig so I'm thinking I'll get another year or two out of mine at least. Your mileage may very though.
Old Mar 14, 2010 | 03:29 PM
wagner262's Avatar
wagner262
Your right z06 sounds about right
u say meth u mean methanol kit right? Where can u find kits for corvettes?
Old Mar 14, 2010 | 04:19 PM
JustinStrife
Call one of the shops nearest to your area, or call Chris at ECS. Pretty much any of the corvette shops that do supercharger installs regularly, will have their own particular brand of methanol injection kits that they prefer. I have a Labonte Stage 3 kit that I got through RPM motors. Replaces the windshield wiper fluid and shoots the meth into the air bridge before the throttle body and intake manifold. Pretty stealth actually as the nozzle is on the bottom side of the airbridge.
Old Mar 14, 2010 | 04:22 PM
wagner262's Avatar
wagner262
Thanks this helps a lot!
How much does a kit like that cost after instal? Or Is it easy to install?
Old Mar 14, 2010 | 04:25 PM
JustinStrife
It depends on what kit you're looking at. They can run you anywhere from 300-400 for the low optioned models, to 600-700 for the higher end ones(might have dual nozzles, or electronic controls). Either way, I'd recommend getting a progressive controller that controls when the meth starts spraying, and increases spray as boost and rpm rises. give Chris at ECS a call and he can get you squared away.
Old Mar 15, 2010 | 11:02 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Thanks Justin
Feel free to call me anytime with questions..
__________________
Home of the Fastest Supercharged C5 8.4 @ 158mph
Home of the Fastest Supercharged IRS GTO 9.0@ 155
Home of the Fastest Supercharged C6 9.7 @ 143mph
Proud Sponsor of the ECS Corvette Challenge
http://www.corvettechallenge.info
609-752-0321
Old Mar 15, 2010 | 03:41 PM
Steve@AandACorvette's Avatar
0Steve@AandACorvette
Former Vendor
From: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
so im getting a c5 in about a month but im thinking in about 6 months i want to put an a&a supercharger on it... Nothing crazy just some extra hp!
So i have options
2003 80k z06
lower mile corvette
115k frc 2000
whats the best choice? Do i have to worry about blowing a ring or piston? With certain milage cars? Whats the best way to go about this?
z06... :d
Old Mar 15, 2010 | 04:38 PM
jerboa's Avatar
jerboa
St. Jude Donor '14-'15
You might want to add headers to the package in the future. If you are going to blow extra air and fuel into the combustion chambers, it's great if you can also exhaust the spent gasses.
I got 656 RWHP on my 2002 Z06 with a blower cam, headers and an A&A Vortech V-3.
I chose the V-3 because it is self contained for oiling and doesn't require you to tap into the pan for your blower oil supply.
To supercharger!
