C5 hot section
Old Mar 16, 2010 | 09:19 PM
LSOHOLIC's Avatar
LSOHOLIC
Default C5 hot section
Looking to put my turboed 370 setup in my C5Z. It was in my F-body with the reverse manifold setup. What are my options for the manifold/header
in the C5?? Because it does not look like the reverse (truck)manifold is going to work. Here are the options I'm aware of:
1) one off custom fab manifolds
2) complete hot sections (Hinson/or other aftermarket manufactors)
I forgot to say its going to be a front mount. What I'm really looking for is a reverse manifold setup thats works(C6) or maybe a shorty header that can be flipped. Thats kind of the mind set on this project. If it matters this is a 04 ZO6. Just post, even if you think I may allready know the lead your giving. I'm interested in every avenue !!!!
Thanks in advance
Old Mar 16, 2010 | 11:45 PM
396375's Avatar
396375
St. Jude Donor '08-'09
Unless you are a real good fabricator I would go TTI or Hinson.I doen't know what size your turbo is but anything bigger then a 76 and you will have to bubble the hood.It might be cheaper to sell your stuff and start again.I know you doen't want to hear that.
Good luck.
Thanks in advance
Old Mar 17, 2010 | 06:38 PM
LSOHOLIC's Avatar
LSOHOLIC
Its a S88, so its pretty big. Hinson seems to make a nice complete kit but all I need is the manifolds or something along those lines.
To C5 hot section
