I am thinking about forging my LS6... in my mind, it is nothing more than a set of forged rods and forged pistons with rings... not that big of a deal.. for those who have done it.. is there anything I am missing other than the usual engine build stuff... gaskets, bolt etc.?
Are you getting a forged crankshaft too? I know the stock one is beefy but I would consider forging the engine to include the crank also. What about bearings?
engine machine work
align hone the mains
hone the cylinders
new cam berrings if many miles
ballance rotating assembly
clean the block
deburr the block
magnflux the block/crank
all of the above could be skipped but then again it is a bit of work to R&R the c5 engine.
engine machine work
hone the cylinders
clean the block
deburr the block
Do it correct the 1st time then no more problem with it. It may be over kill. But the old saying is it is only as stong as the weakest part. Good luck with the build..
