procharger questions
Old Apr 2, 2010 | 03:50 AM
electronZ06vette's Avatar
electronZ06vette
Default procharger questions
im looking for 550-600whp for now but only until i get a built motor in. is a F1A too much to run this low for now even tho i will crank it up in the future or will this be fine for now? why do people have trouble when they go up to 10-12psi with belts and what not? are the people running 20psi on cog setups or what?
Old Apr 2, 2010 | 10:01 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
For the HP level you want a PS1C or DS1C is what you need, if you get a F1A you will not be spinning it to get those levels you want. I run 20# with the latest A&A Bracket and his orginal IC and this is with a DS1C
Old Apr 2, 2010 | 10:30 AM
a/c man's Avatar
a/c man
Default max boost!
im runnind a P1 on the new A@A bracket it works awesome with a 6 rib belt 3.50 pulley makes 8-10 psi on my 402 would make about 14 psi on a 347! its maxed out on boost! so im going with a D1 this weekend im hoping to get 14 psi. (my polished P1 is for sale) 10 psi is about the max boost you want on a stock piston! i hope this helps
Old Apr 2, 2010 | 02:04 PM
tail_lights's Avatar
tail_lights
With what they said!
Old Apr 2, 2010 | 02:26 PM
electronZ06vette
so running an f1a would not be recommended even at 6-8 psi? i would rather run a bigger blower at lower boost and get the same results as a smaller blower at higher boost anyways and i know the f1a will get me at least 550whp on low boost. when i go built i will be getting a ls3 418 and shooting for 700-800whp on pump and bumping it up for race gas. will the p1sc1 get me the results i want? basically i want something has a lot of room to grow and ive seen the f1a go 1100whp on ls3 motors and would like to have that but thats in the future.
Old Apr 2, 2010 | 06:54 PM
HotRod68Camaro's Avatar
HotRod68Camaro
I don't see a problem with going big early, thats what i did. If your going to put in a forged motor anyways, then you might as well. If your only looking for 800s, there have been plenty of people hit that with a D1.
Old Apr 2, 2010 | 08:28 PM
a/c man's Avatar
a/c man
F1A run it with a big low boost pulley!! but a P1 is too small to grow into! d1 will work up to 800rwhp!
Old Apr 2, 2010 | 09:24 PM
happa's Avatar
happa
I'd say start with a P1, thats what I have and I made 705 rwhp. on a 3.85 pulley. Then when you get bored with that move on up! Good Luck!
Old Apr 3, 2010 | 01:14 AM
electronZ06vette
thanks for the input guys! what pulley can i get for the f1a that wont put me over 10psi?
i want 800 on the street and over 1000whp on the track and i dont think the d1 can hit 1000?
Old Apr 3, 2010 | 10:34 AM
a/c man's Avatar
a/c man
really big pulley!! 4.38 just call procharger and ask!!there cool!!
Old Apr 3, 2010 | 11:17 AM
HotRod68Camaro
Im not sure how the F1A compares to the F1C, but for my stock shortblock i had to use a 5"pulley and it still made 700whp. So i had to use a restrictor plate to bring it down more. I have never heard of a D1 hitting 1000whp. It's still going to be a lot of work for the F1 to hit that but doable.
Old Apr 3, 2010 | 02:02 PM
electronZ06vette
the f1a is a little smaller and flows 200cfm less than the f1c and is rated at 1100 and the f1c is rated at 1225. haha thats awesome you had to use a restrictor plate and a 5" pulley and STILL made 700whp! how much boost was that 5" pulley making? i think the f1a will put me right around 550-600 whp on low boost (i.e ~7psi) which is perfect for me for now until i get a built motor in.
Old Apr 3, 2010 | 02:25 PM
HotRod68Camaro
It made 700 with the pulley. The restrictor plate brought it down to 613. At 700 it was 11-12lbs, at 613 it was right at 6lbs.
Old Apr 3, 2010 | 03:56 PM
a/c man's Avatar
a/c man
it sounds like bigger blowers make more hp at the same boost am i right or is boost just boost? would a P1 with 10psi be the same hp as a D1 with 10psi?
Old Apr 3, 2010 | 04:00 PM
joshtownsend's Avatar
joshtownsend
Yes, it just hits hard and faster...So the Dyno graph looks better
BTW Texas FTW!!!!
Old Apr 3, 2010 | 11:37 PM
uniquec5's Avatar
uniquec5
I have an F1a with a 4.25 pulley on a stock cube and is making 18.5 lbs of boost..
Old Apr 3, 2010 | 11:57 PM
electronZ06vette
ok cool 600whp is the max i would want because i dont want to be pushing it haha. sounds like f1a and 7psi is when im going to be at!
Old Apr 4, 2010 | 10:40 AM
tail_lights
Originally Posted by HotRod68Camaro
(with the 5" pulley) At 700 it was 11-12lbs
Originally Posted by uniquec5
I have an F1a with a 4.25 pully on a stock cube and is making 18.5 lbs of boost..
really big pulley!!
Might have to see if you can get a crank pulley modified to run that F1
Old Apr 4, 2010 | 05:46 PM
Edward J. Osterman's Avatar
Edward J. Osterman
Default Trouble figuring out how to reach an FO owner
How do I contact a member to discuss his Procharger set up?? His ID seems to be "cdnws6" as listed in the FI Owners Club organized by Sticky.
Thanks, Ed
To procharger questions
