Flow Matched High Flow LSx Injectors
We now have available and in stock GM factory re sized injectors for LS1/LS6, LS2 and LS/7's that are flow matched and upgraded to support 750 + horse power applications.
We can also custom make a set based on your wants and needs, or get you another non LSx set depending on your application.
LS2 72lbs:
$325.00 shipped - lower 48.
Perfect for any LS2 car in need of more fuel with no adapter's needed, will also work with LS1 and LS3 but will require either spacers or injector connector adapters. Able to support up to 750 + hp. The 60lbs is based on 3 bar, or 43.5 psi, where as LS cars run 4 bar at 58psi, which on LS fuel pressure of 58 is 72.25lbs. If needed we may be able provide the adapter kit based on your specific application.
LS3 72lbs:
Perfect for any LS3/L76/LS7 car in need of more fuel with no adapter's needed, will also work with LS1 and LS2 but will require either spacers or injector connector adapters. Able to support up to 750 + hp. The 60lbs is based on 3 bar, or 43.5 psi, where as LS cars run 4 bar at 58psi, which on LS fuel pressure of 58, is 72.25lbs.
LS1 48lbs:
$300.00 shipped - lower 48
We can provide an injector flow rate slope for these injectors.
Please call us at 813 476 7364 for Visa, MC, and AMEX payment, or you can Paypal at fastprom@tampabay.rr.com
If you use Paypal, please include your shipping address or reply/PM back here with it.
Our address is
Fasterproms
19103 Sunlake Blvd
Lutz, FL 33558
