Procharger ??
Old Apr 10, 2010 | 07:05 AM
jeffrey757's Avatar
jeffrey757
Default Procharger ??
I have a 2002 z06 with a procharger, I think the belt is making noise, its got a little squeal coming from it. Not sure if its the belt or something else, Please help.. need it fixed before i take it out for the summer. Thanks..
Old Apr 10, 2010 | 08:35 AM
SmoothFRC's Avatar
SmoothFRC
Does your kit use the stock tensioner? They are notorious for squealing - but so are the idler pulleys....
Old Apr 10, 2010 | 08:45 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Does it go away? If so when?
Does it sound like it is coming from the lower section? if so that could be the AC tensioner!
Best suggestion: Jack it up, put down some jack stands, do a cold start, crawl under it and determine where the sounds is coming from. From my experience you can have a lot of slack in the belt thus allowing some slop when cold and maing it squeel, then once warmed up the heat helps it to take up and the squeel goes away.
Now if it is always there and it sounds like a chirp then that points a little more towards a idler pulley or a tensioner pulley - I had to update all mine on the AC system, due to a bad tensioner, so I did the idler too since I was already down there
The cool thing is is that they are relatively inexpensive to get and readily available
Let us know what you find!
Thanks,Matt
Old Apr 10, 2010 | 07:21 PM
C5VERTMAN's Avatar
C5VERTMAN
IDILER PULLEY FIXED MINE
Old Apr 10, 2010 | 09:58 PM
user_name's Avatar
user_name
get 1 side of the belt damp at a time. That will tell you if it is the belt.
Old Apr 11, 2010 | 01:43 AM
tail_lights's Avatar
tail_lights
Start there and report back!
Old Apr 11, 2010 | 12:08 PM
a/c man's Avatar
a/c man
check the oil in your procharger!! also replace the belt!!
Old Apr 11, 2010 | 01:07 PM
robinde's Avatar
robinde
Try the goodyear gatorback belts.
Old Apr 11, 2010 | 07:00 PM
95wht6spd's Avatar
95wht6spd
My noise is caused by an alignment problem w the idler. Any belt wear, dust?
To Procharger ??
