Procharger Questions
Old Apr 10, 2010 | 10:00 PM
giwhop's Avatar
giwhop
Default Procharger Questions
Im looking at a 02 zo6 with a supercharger and the guy is telling me it has a 3.12 pulley what kind of boost should the car make and can the stock motor handle the boost is there anything i should look for also noticed in the pictures one side of the borla exhaust has alot of carbon build up is that normal.
Old Apr 10, 2010 | 10:21 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Depending upon if it is running headers and or Hi-flow cats or none will all add into the total of Boost being run.
If it is basically stock it should be putting down qround 12-13+ PSI of Boost and yes the C5 Z06 can handle the Boost, remember that the LS6 motors metal is different than the base LS1's (with the exception of the '04 block) -
More than likely the black sut you see is from a little fatter tune fore safety - and usually from one side of the mufflers exit tips because in a dual tip there is always one side that flows more
Do you have anymore info on the Vette, perhaps what the original owner has done to it? or is it basically stock?
any and all upgrades along with informatio will help us determine what it will do or is doing!
What does the owner state the RWHP and RWTQ are right now as it sits? Find out who did the tuning etc. - This will help too
Thanks,Matt
Old Apr 11, 2010 | 12:12 PM
a/c man's Avatar
a/c man
never herd of a 3.12 pulley? 3.20 is the smallest procharger has! they always have dirty black tips we clean them a lot!
To Procharger Questions
