supercharged c5 transmission problem
Old Apr 11, 2010 | 06:44 PM
corvettekaan's Avatar
corvettekaan
8th Gear
Default supercharged c5 transmission problem
my car is 2000 model automatic transmission c5.I have just installed p1sc supercharger 8psi boost +70hp nitrous.We have to upgrade our transmission,what parts do we have to install in order to drive it safely on full throttle.It has to stand up to 750hp.
Old Apr 11, 2010 | 08:28 PM
HP_Addict's Avatar
HP_Addict
look into RPM transmissions.
Old Apr 11, 2010 | 09:22 PM
uniquec5's Avatar
uniquec5
RPM is a good start. But look around. There are many shops that can build a trans to your hp needs not just RPM.
Old Apr 12, 2010 | 02:54 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I agree, Give the guys over at RPM a call.
http://www.rpmtransmissions.com/
Old Apr 12, 2010 | 07:11 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I am on board here as well - BUT if you have a local "TUNER" who recommends a good tranny shop that knows our Vette's you could go that route - That is what I did and it is great!
But make sure you compare them to RPM, parts and price - because if you don't you can end up paying more and getting less - So it would then be best to purchase a RPM tranny and have it installed instead
Thanks,Matt
Old Apr 12, 2010 | 04:54 PM
corvettekaan
8th Gear
thank you. Are there any other ideas?
To supercharged c5 transmission problem
