Most HP out of a Blown 346
My 346 was probably mid 8's?? But didn't care about dyno numbers.
787rwhp stock bottom 346ci here. 696ft-lbs. 11.5 pounds. 93 pump. 12 degrees of timing. Twin 67mm turbos. 60 pounders. Maxxed out fuel system(out of gas @5800rpm). SuperFlow load bearing chassis dyno.
Borrowed time on a stock bottom.......
Just got mine back after 15 months of hell. Forged 402 custom built, studded all around, Trickflow's ported/polished, eight rib Novi, Fast 92 ported polished intake/TB, ECS Stage II fuel system, Meth. with a stage IV RPM A4, Pro-Charger red BOV, big lift cam with 12 degrees between duration, and an 11" 3400 Yank Nitro's converter. Made 700 rwhp @ 5500 and ran out of fuel with 60# Motron injectors running @ 14/1 AFR (by design for break-in). Saving for the 80#'s Siemons.
I was planning on racing this summer but with all the b/s I have had I'm just going to enjoy the car for a while. I can't afford anything more to break on the car or break my marriage.
Anyone that leans on the car with a stock bottom end with boost is just buying time (as long if one dosen't get greedy). The engine was not design for that.
Those damn turbos are so efficient...lol. I'm doing 713rwhp on the stock bottom with a t-trim, but it takes 18 degrees of timing. I wouldn't dare try near 800 on the stock bottom end.
what do you guys think I'll get out of this build to be done by A&A
Forged LS6 short block (stock cubic inches) Includes LS6 block torque plate
honed to 3.905, Diamond forged pistons (8.6 CC dish), Akerly & Childs file fit
rings, forged 6.125" connecting rods, OE crankshaft
Custom grind A&A camshaft
HD adjustable timing set
GM Performance oil pump
ARP main studs
Patriot CNC ported heads with stainless valves, dual springs, titanium
retainers, hardened locks and new seals
ARP head studs
GM Performance lifters
A&A supercharger system with T Trim upgrade.(self contained)
Upgrade to 8 rib belt drive
add Boost A Pump to system (in tank pump is included)
Methanol injection kit
ARP main studs
ARP head studs
Please.
Just because you had a tune issue or a driver mishap and blew your car up....doesn't mean it's going to happen to me. Yes,..I know,...."550rwhp" is the magic internet safe standard rating. Not here. The motor HAS been removed,...and is currently in another daily driven vehicle. Motor is fine.
My guess would be 750-800rwhp.
ARP main studs
ARP head studs
ARP main studs
ARP head studs
