Idle problems
Old May 2, 2010 | 01:24 AM
jjnitrox's Avatar
jjnitrox
Default Idle problems
Hi Guys:
I have a 00'vette with a ls2 and a P1SC-1procharger kit. I also have a 232-240 with a lift of 595 and 608 cam the degree is 114. My problem is When I turn the AC on the engine shuts off.I have been told that if you drill a hole on Throttle blade I should be able to fix it. Is this true? if it is true how big should it be? I know that all engines are different but where should I start? any other solutions? My tunner is using E-live.Guys I know when you use big cams this things happen just asking for help.
Old May 2, 2010 | 01:27 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
That cam isn't too big. You can tune it out. Drilling a hole is an old cheat. There are some idle adaptive/compensation tables that you can use to add airflow/timing when the A/C is on. That's where you need to be looking. Where do you live?
Your idle tuning could be on the edge by itself and turning on the A/C is pushing it over. Make sure you tune the idle airflow first and then work on the compensation.
Old May 2, 2010 | 01:35 AM
bullitt4110's Avatar
bullitt4110
That cam is far from to big, I have that same size cam in my car right now but on a 117. Do not drill a hole in the TB blade, just get the idle tuned correctly.
Old May 3, 2010 | 03:57 PM
Arun@ChampionMotors's Avatar
0Arun@ChampionMotors
Former Vendor
Anyone with HPTtuners around-I can help you fix it.
Old May 3, 2010 | 06:59 PM
Ronnie_W's Avatar
Ronnie_W
Old May 5, 2010 | 10:03 AM
E.jones's Avatar
E.jones
Im having similar problems on my 402 build.
Old May 9, 2010 | 05:21 PM
edcmat-l1's Avatar
edcmat-l1
They're all tunable. Some just take a little more work than others.
To Idle problems
