We sell and all aluminum replacement radiator for your car and it is even more capacity than the Dewitts. Our have dual 1 1/4 cores for a total of 2 1/2' thick!
Steve
According to becool, the thicker cores can be a problem
I don't know who you talked to but this isn't true. Our fan package is designed to fit the stock radiator, our radiator, or anyones brand radiator as long as their mounting brackets are in the stock locations.
tom,
it was a woman i spoke with...lol...i forgot her name tho...
but on a side note atleast i know that the fans will work w/ my stock rad....
Sounds like I may need to try the SPAL fans on my stock rad. and see what happens after the twins are installed and everything is tuned including the temp at which the fans to come on.
My initial concern was a fitment problem that I may encounter with a thicker rad. and TTI's big front inner cooler.
Where do you TTI guys mount your external oil cooler?
