This is only becuase they don't blow up like the older ones did. From what i was told, they did fix the problem, but I think you would be disappointed in the total results VS the money spent.. maybe 10-15 hp for $1500 spent over an ls6 on a stock to stockish motor. bigger cubes maybe more, but not much
I'm a believer. Especially if your FI. Always ran a FAST 90 on my boosted setup... I wouldn't ever change it. Unless I build a sheetmetal manifold,..more then likely going to be running a FAST 102 @20psi+ on my own setup very soon. I did blow up a fast 90 but that was due to a nitrous backfire.
That's pretty much what I was thinking I'd gain (10-15rwhp) by doing the swap from my current LS6 manifold. I would have it ported as well If I decided to do it. Kinda hard to justify the expense though...if I knew I'd gain 20rwhp then I'd spend the money.
Looking forward to your results. I'm running 19psi at the moment, and might up the boost.
My car picked up 30 rwhp over a ported LS7 intake with a box stock 102mm intake. 440ci motor.
Thats a good gain.
Are the extra 30 or so HP worth more than bragging rights when you get north of 700 rwhp though? Don't get me wrong, I had a perfectly good 9 second car and changed everything out for more HP
For what I do with my car you bet its worth it. For some the hp from the intake doesnt validate the costs, but when you are trying to get every ounce of power out of a combo 30hp is well justifies the expense.
Cant us what power these F/I makes at this point. Have to paddle into it all the way to 75 mph now. If a person is doing it just to say I have what ever the # is, then I guess yes it is. But then put it on the track or from red light to light or 1/4 someplace and see how that corvette gets the rubber to the road with his foot to the floor.
...just need to make power. As much as possible. Couldn't really care too much about a dyno number, just how it performs on the street. 30rwhp on a dyno is only part of the number when your on the actual street/strip under load. Everything matters. If your just trying to make "700wheel" or 800--whatever..and you do that with a stock manifold,...sweet. I'm trying to get this thing stupid fast in the mile,... I need all the help I can get.
I'm not the only one that has had fitment issues on a C5 using the 102's. There are a few ways to skin that cat, but if you want the biggest baddest plastic intake around then just make it work. There's no such thing in life that's a "bolt-on."
The LS7 I put it on pulled much harder to 7k than it did with the choked up LS6/Stock TB.
I've been at almost all of the events. Last few events, I have been driving an 09 V(black). My white FRC has been apart for a while but,....thats the type of event that I gearing it for.
Exactly what is needed to make it work on a C5 since I am gonna pull the trigger on it possibly?
