Something so simple....
Old May 23, 2010 | 11:37 AM
Zosickness's Avatar
Zosickness
Default Something so simple....
So, can anyone guess what happens when some IDIOT leaves a Scotchbrite pad in your oil pan?
That's right folks. It breaks into pieces and clogs up the oil pickup tube and you wonder why you have zero oil pressure. Kinda strange how people can forget the little things like that.
On a side note....my meth pump failed.
So far it looks like I just need to replace all the bearings in the block.
Old May 23, 2010 | 02:47 PM
happa's Avatar
happa
sorry man, thats some crapy luck
Old May 23, 2010 | 04:12 PM
Z06PSI's Avatar
Z06PSI
St. Jude Donor '17-'18-'19
Who is the idiot?
Old May 23, 2010 | 04:27 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Sorry to hear about that man.
On a side note, my meth pump failed last week also but have already replaced it. For anyone who has the AlkyControl pump mounted in the drivers side fender, you NEED to get the rubber sock that covers it or it WILL fail.
Old May 23, 2010 | 06:43 PM
SmoothFRC's Avatar
SmoothFRC
? from water?
is Julio giving the socks out to everyone? Havent used my pump in 6 months or so... guess i should test it.
Old May 23, 2010 | 09:06 PM
Vince99FRC's Avatar
Vince99FRC
I am on my second pump and the second was installed by Julio himself. Running strong since he installed it over a year ago.. I do all the test b4 taking off to make sure it is working..
Sorry to hear about your motor!!! We assume since you are not sharing who did this they are helping you recover your loss... Which would be the right thing.
Old May 24, 2010 | 12:28 AM
SilverZohsix's Avatar
SilverZohsix
i don't understand how someone could accidentally leave something in an oil pan, let alone install it with it still laying in there...
Old May 24, 2010 | 01:01 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Sorry to here of your woes. Using scotchbrite pads on engines is a big and GM has a tech bulletin out on it somewhere.
Old May 24, 2010 | 04:25 AM
Zosickness's Avatar
Zosickness
Originally Posted by Z06PSI
Who is the idiot?
I can't be sure who the idiot is, so rather than make an accusation I'm keeping it to myself. I'm a contractor in Afghanistan and at various times had to have work done. If there was only one shop that worked on my car I would say. All in all this isn't an expensive fix considering that I'm tearing apart my motor now to put some lower compression pistons in it anyways. So, I'm paying out of pocket.
Old May 24, 2010 | 07:26 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Glad it's not worse.
Old May 24, 2010 | 07:42 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
damn.
Old May 24, 2010 | 09:29 AM
Corvette-Chris
St. Jude Donor '08
Originally Posted by SmoothFRC
? from water?
Yes, from water. My IAT's werent responding like they should have so Taylor pulled the pump off and removed the bolt that basically goes through the body of the pump. It was FULL of corrosion. He just started shipping pumps with the socks in January. I dont think he is "giving" them out. Water damage is not something covered under warranty, from what I was told.
My pump light would come on during tests, but it was still not flowing like it should have been. Hopefully your new pump has a sock on it.
To Something so simple....
