FI pcv check valve
Old May 24, 2010 | 07:06 PM
jimish's Avatar
jimish
Default FI pcv check valve
Does anyone have a mfgr. name and model for a check valve to put in front of the pcv valve so you don't feed boost into the crankcase? Also, If I use a puke tank (oil breather), should it be a closed system or can I use a catch can with a small breather filter on it (cause thats what I happen to have one of) What size hoses should go to this can?
Old May 24, 2010 | 07:35 PM
denscor's Avatar
denscor
I have an extra one let me know.
Old May 24, 2010 | 08:05 PM
jimish's Avatar
jimish
I would be interested in buying it if you pm your address and price. Can you help with the other info? Thanks
To FI pcv check valve
