forged 346
Old May 30, 2010 | 09:01 PM
mustangracer's Avatar
mustangracer
Default forged 346
I have been saving up to build the vette for boost and want something reliable and not have to worry about putting a hole in the piston or bending a rod. Now i know the rods/pistons are the weak spot in the ls1 so I am thinking of doing stock size forged pistons and rods ( I dont want to start bore/decking/machining thats when it gets expensive). Now will these pistons and rods do the job with no machining and keeping or lowering cr:
http://www.texas-speed.com/shop/item...d=116&catid=38
http://www.texas-speed.com/shop/item...d=699&catid=39
If this bottom end setup would work together about how much hp would it take? Any other recommendations for weak spots?
Thanks for any help and all suggestions
Old May 30, 2010 | 09:11 PM
robert miller's Avatar
robert miller
Default ttt
That will work for no more than you are looking for, but look at the heads and V/springs for the heads. That is if you are trying to get by cheap. But if you can look at getting the parts bal.
Old May 30, 2010 | 09:29 PM
mustangracer
Im going one step at a time, but what heads would you recommend. Im not really looking to spend 2k on a set but im not trying to be cheap either(ive learned my lesson ) Maybe some 243 ported a good bit with springs and valves?
Old May 30, 2010 | 09:47 PM
DRK-SYD's Avatar
DRK-SYD
I have a forged 346 with 6.0 liter truck heads unported. I'm running a f1C making 817 rwhp and 690rwtq. So I think you'll be just fine.
Old May 30, 2010 | 10:03 PM
mustangracer
thats WAY above what im shooting for so that makes me feel much better, so the 6.125" rod wont require any mods? (I couldnt find the stock rod length)
Old May 31, 2010 | 10:38 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
I run 243 chambered out to 72 CC and my little ole 347 has been together for 5 years now
Old May 31, 2010 | 11:04 PM
robert miller
I wish I had it still with a 347 motor.
Old Jun 1, 2010 | 10:42 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Thanks Robert
To forged 346
