Anyone need an LSX block?
Old Jun 6, 2010 | 02:57 PM
DBN's Avatar
DBN
Default Anyone need an LSX block?
I have a new LSX block for sale in the parts section.
Old Jun 6, 2010 | 04:22 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
ok!
Old Jun 6, 2010 | 04:59 PM
joshtownsend's Avatar
joshtownsend
10-4 roger
This reminds me of a talk i had with a few different people. On a blower car, why would you get a LSX block instead of a, say a 6.0. you could easy have $8k in the LSx block and $3k in the 6.0 and let the blower make the power...
I'm curious as to what others think.. I could certainly stand to lose a $3k motor but not so much a $8k motor
Old Jun 6, 2010 | 08:54 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Originally Posted by joshtownsend
10-4 roger
I would pressume the benefit to be that the Lsx block has 6 bolts per cylinder vs the 4 of the iron block. Additionally the wider bore would allow various piston and crank strokes.
I'm not sure what the max bore is on a 6.0 Iron Block (Lq9) ? But you could do a 4.125 with a 3.622 crank and end up with a 5.7 liter killer motor, very similar to what the C5R was running.
Old Jun 6, 2010 | 09:31 PM
joshtownsend
Yeah, I get the added strength and all.. Generally speaking, most of us, including me, will never push both blocks to their limit. It seems that more people talk about getting them and its over kill. You could also most get 3 engine for the price of one... and the iron block is pretty stout itself. oh well to each it's own.
Old Jun 6, 2010 | 10:06 PM
uniquec5's Avatar
uniquec5
Im looking to buy a block but looking at the rhs. Here is a bump for u!!
Old Jun 6, 2010 | 10:36 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
It's not so much the added strength as it is the ability to keep the heads planted on at high boost levels with not block distortion, like aluminum gets.
It just depends on what you're going to build. 600 - 650 RWHP is plenty in my opinion, but some guys want the magical 1,000 RWHP + and this is the block for that.
Old Jun 7, 2010 | 05:38 AM
clif's Avatar
clif
St. Jude Donor '09-'10
I have a new LXs in my garage. I've ordered the rotating assembly, and am waiting for that to come in. I am going with a 454 cubic engine; which is a 4.125 stroke and a 4.185 bore. I am taking my time with this engine, and want to make sure it is perfect.
Old Jun 7, 2010 | 09:12 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
That's a lot of motor.
Old Jun 7, 2010 | 11:23 AM
gorillavet's Avatar
gorillavet
I have a LSX block and would not consider anything else. I run only about 14 pounds on the street but up to 20 pounds at the track and could go much higher with larger turbos. Six bolt heads and NO PUSHING WATER! My LSX block was not that much more than a truck block. Now the downside..........weight and heat as that iron block does hold the heat much more than aluminium.
Old Jun 15, 2010 | 09:37 AM
DBN's Avatar
DBN
It's still for sale.
Old Jun 15, 2010 | 10:40 AM
396375's Avatar
396375
St. Jude Donor '08-'09
Geez Tony.You mean I chose the wrong block?Sh*t!
Old Jun 18, 2010 | 12:00 PM
gorillavet's Avatar
gorillavet
GEEZZZZZZ......what you think a LSX block cost. Check Summit.......you might be surprised!
Then.......check a C5R block!
another bump for ya!
To Anyone need an LSX block?
