SC Install question
Old Jun 7, 2010 | 09:22 PM
bmg's Avatar
bmg
Default SC Install question
The procharger instructions are telling me to connect #3 to #2 with a T connector and then run the other end of the T to the front of the air filter
The directions do not say anything about what to do with #1
Right now #1 is connected to #2 with a U shaped hose containing the PCV valve.
Thanks in advance!
Old Jun 7, 2010 | 09:52 PM
HP_Addict's Avatar
HP_Addict
not sure about a procharger, but the way I have seen it is:
2 runs to a catch can and through the PVC and back to 1
3 either gets capped and a filter added to the oil cap or 3 gets a line ran to the air filter.
Old Jun 8, 2010 | 09:38 PM
01vetter's Avatar
01vetter
Don't forget to install a check valve between 1 and your PCV.
To SC Install question
