When I installed my alki system a while ago I haden't seen the posts on the plastic hat for the top of the pump. I also had seen posts showing the pump mounted both ways, pump on top and pump on the bottom. Logic says, pump on the bottom to prevent a potential leak of the pump seal allowing fluid into the motor.
I have kept loads of pumps like this running on systems on a cruising silboat so I put the always used half of a plastic bottle over the top of the motor. Then while looking things over before I buttoned up I noticed the dreaded teat hanging down pointed right at the motor. If Ya have ever seen a milking machine you would have had the same idea I had. Slip a piece of scrap rad hose over the teat and direct the flow down past the pump to the rocker pannel.
If I am preaching to the chior here forgive me but for the new guys--these pumps are $$$$, a wash and wax lad will drown his new pump in no time.
Guess I was lucky. My pump lasted about 18 months, before it seized up from water. After I talked with Julio, he let me know he has covers now. So, I bought a new pump with cover and got it installed. Thanks Julio for the support!
you must not get into rain at all with the car. Julio is one of the car guys for sure...
