Fuel pressure at boost
Old Jul 5, 2010 | 01:07 AM
matt75's Avatar
matt75
Default Fuel pressure at boost
I have an a&a kit (v3 si-trim) and was wondering at about 10lbs boost, what's an acceptable drop in fuel pressure?
Old Jul 5, 2010 | 06:19 AM
breecher_7's Avatar
breecher_7
DROP???????!!!!!!! There should be no drop at all.... Fuel pressure should be boost referenced to INCREASE on a 1:1 ratio.
Old Jul 6, 2010 | 12:56 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Only if you're using an aftermarket regulator.
If you just have the stock fuel system, I wouldn't want to see less than 50psi.
Old Jul 6, 2010 | 02:57 PM
tail_lights's Avatar
tail_lights
With the stock system I have heard that low 50s is acceptable. Now it can be tuned around if there is a further drop, however it is not recommended.
Old Jul 6, 2010 | 04:32 PM
zeevette's Avatar
zeevette
The system comes with a Lingenfelter FP, so it's not exactly stock.
Old Jul 6, 2010 | 05:45 PM
BLOWNBLUEZ06
I am really just talking about the fuel pressure regulation side of the system.
I also need to mention that the 50psi cutoff isn't a flat number, meaning if you go up in boost, you decrease your yield and the higher the cutoff point should be. 50psi fuel pressure and 10psi boost yields only 40psi. Change that to 15psi boost and now your yield is only 35psi. That's way unacceptable IMO.
Old Jul 10, 2010 | 09:01 AM
z06sicz's Avatar
z06sicz
I seen a drop to the low 50's with that pump and the V3 A&A kit injectors. My tuner kept throwing fuel at it, but I think we were at the limits of the pump and or rails. Made 618 to the wheels Avg AFR was approx 11 from 3-6K and dipped toward 13 from 6-6600.
Old Jul 24, 2010 | 06:58 AM
rclinton's Avatar
rclinton
Veteran: Marine Corps
I think the limiting factor at least in my 2002 is the fuel regulator. I saw 57 psi with the stock pump before the A&A install and still see 57 psi solid after the install with LPE pump and larger fuel injectors. Obviously the LPE pump is pushing more GPH but is regulated to 57 psi by the regulator. Im running a V-2 kit though with 6-7 boost.
To Fuel pressure at boost
