Damaged Idler pulley
Old Jul 6, 2010 | 11:26 PM
SCRMNC5's Avatar
SCRMNC5
Default Damaged Idler pulley
Changed the belt tonight for the first time by myself and noticed that the tensioner that the back of the belt rests on nearest the supercharger pulley is chewed up towards the front of the car. Now I know why I'm ripping ribs off the belt. My ? is what could cause the tensioner to get chewed up like this. I should have took a photo of it , but totally didn't think of it at the time. Would heat play a roll in this?? Any info would be greatly appreciated!!! Thanks.
Barry
Old Jul 7, 2010 | 12:43 AM
a/c man's Avatar
a/c man
get a new pulley and go try it again! you may never know the cause
Old Jul 7, 2010 | 01:47 AM
joshtownsend's Avatar
joshtownsend
you mean liek this??
Old Jul 7, 2010 | 07:15 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Can you try one of the METAL Idler pulley's?
I know someone will throw out the part number for it - Call CARTEK I think MAX might know!
Thanks,Matt
Old Jul 7, 2010 | 09:19 AM
Max@Cartek's Avatar
Max@Cartek
To reduce the chance of this happening again you should get an aluminum pulley version that has been hard anodized. When the belt tension gets high the plastic idlers wear quickly. These pulleys on the SC kits are seeing quite a bit of load.
What kit are you running?
Max
Old Jul 7, 2010 | 10:42 AM
a/c man's Avatar
a/c man
Max
I have one new for $50
Old Jul 7, 2010 | 12:55 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
I would replace all the plastic idlers if I was you, along with your tensioner to a HD one, they really do not belong on a supercharged car. Arun at Champion has come up with a bolt in unit for your application.
Old Jul 7, 2010 | 02:45 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
I've seen that happen twice on 2 separate occasions when a large spacer was placed under the tensioner rather than the skinny one on an A&A kit and then set the tensioner right above it where it was rubbing.
Old Jul 7, 2010 | 10:09 PM
SCRMNC5's Avatar
SCRMNC5
Yup, but worse than this!!!!
Old Jul 7, 2010 | 10:11 PM
SCRMNC5's Avatar
SCRMNC5
Max
Hey Max, I'm Barry, Rob's friend from CT, we came down a few times. I'm running the procharger kit, D1SC. Came directly from Por Charger.
Old Jul 7, 2010 | 10:12 PM
SCRMNC5's Avatar
SCRMNC5
If this is the one that Max is talking about, I'll take it, what's your paypal if you have one.
Barry
Old Jul 7, 2010 | 10:38 PM
a/c man's Avatar
a/c man
Barry
yes its the best pm sent
Old Jul 7, 2010 | 10:41 PM
a/c man's Avatar
a/c man
I have 2 plastic ones also 1 new 1 is like new but used thanks scott
Old Jul 8, 2010 | 09:28 AM
Max@Cartek's Avatar
Max@Cartek
Hey what's up?
Give me a call when you get a chance. I can give you some pointers on other things to look for while you are in there.
Later,
Max
(908)317-4496
Old Jul 8, 2010 | 01:43 PM
joshtownsend
That is caused by the belt being too tight.
The belt is suppose to be looser then most think
To Damaged Idler pulley
