BAP location!
Old Aug 31, 2010 | 05:56 AM
Boost-it's Avatar
Boost-it
Cruising
Default BAP location!
Hey guys,
Would like to see how\where did you mount your BAP and arranged your wires and if you isolated the relay! coz mine is kinda messy
Thanks,
Old Aug 31, 2010 | 08:18 AM
Its Bruce's Avatar
Its Bruce
Driver's side rear fender well.
http://www.cajundude.com/bap.htm
Now please, clean your engine bay.
Old Aug 31, 2010 | 09:11 AM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Damn that is one filthy hot mess!
Old Aug 31, 2010 | 11:16 AM
corvettebob1's Avatar
corvettebob1
Your MSD BAP will mount in the drivers side fender well behind the tire and you can tuck the relay below the fuse box. It just unsnaps from the lower support.
And I'd move the fuse to a more access-eve location just make sure to only use solder connections and no crimp connectors.
CLEAN THAT ENGINE COMPARTMENT!
Old Aug 31, 2010 | 11:41 AM
96mogt's Avatar
96mogt
+1 the fender well, it cleans up very well over there. Jay
Old Aug 31, 2010 | 02:42 PM
Steve@AandACorvette's Avatar
0Steve@AandACorvette
Former Vendor
From: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
Rear driver's side fender...
Old Sep 1, 2010 | 11:19 AM
corvettebob1
That's a good location for a KB BAP but the OP has a MSD and needs to connect to the intake manifold since it's boost activated.
Old Sep 1, 2010 | 02:08 PM
Former Vendor
We run the wires for the pressure switch up the front and out by the brake booster. Put the pressure switch right there.
http://www.aacorvette.com/pdf/aa_bap_install.pdf
Old Sep 1, 2010 | 06:11 PM
STL94LT1's Avatar
STL94LT1
Mine is placed next to the battery, vertically on the inner fender well.
To BAP location!
