Fuel system upgrades
Old Sep 5, 2010 | 08:37 PM
Munch's Avatar
Munch
St. Jude Donor '10
Default Fuel system upgrades
I've seen a lot of threads on upgrading the fuel pump and adding a hotwire kit when getting up to certian HP levels. I haven't seen any threads about adding a hotwire kit to the stock fuel pump. What kind of gains can be expected with just adding the hotwire kit?
Old Sep 8, 2010 | 03:41 PM
utryd2's Avatar
utryd2
Hotwire kit is for a upgraded fuel pump and kb bap.
I have a fuel system for sale that made 660rwhp and stayed at 60psi fuel pressure.
pm me if you want details.
Old Sep 8, 2010 | 04:42 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
The hotwire kit is a heavy duty harness that pulls power for the pump directly from the alternator, bypassing the majority of the OEM wiring. Racetronix says you'll see more flow on any pump due to the increased voltage.
"The Racetronix PnP upgrade harness provides alternator-direct power for maximum pump voltage. Racetronix has documented an average 1.0-1.2V increase in pump supply voltage on the 2003+ C5. This equates to a 10-15% increase in pump volume."
http://www.racetronix.biz/itemdesc.a...H%2D008&eq=&Tp=
Old Sep 8, 2010 | 09:26 PM
Munch's Avatar
Munch
St. Jude Donor '10
Thank you sir.
Old Sep 9, 2010 | 03:28 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
It will help on a stock pump as well - I know quite a few that have employed the Hotwire kit on the stocker and it's doing a good job -
at the "VERY" least there is peace of mind that you are not getting "DIRTY" Voltage to the pump, but clean voltage right off the back of the alternator
Buy it slap it on
Thanks,Matt
To Fuel system upgrades
