another fuel pressure drop problem
Old Sep 7, 2010 | 04:52 PM
spoolin7's Avatar
spoolin7
Default another fuel pressure drop problem
just got my A&A kit installed over the weekend. I can only assume the pump is stock. it was previously modified and the owner didn't mention a pump change. i have a kenne bell boost a pump wired in right now. it holds right at 58-60psi of fuel pressure until around 6k, then it drops drastically. while doing some street tuning last night, we saw it drop as low as 38psi. i know the pump more than likely needs to be replaced, but it should still be able to hold more pressure than it is, i'd think. i have confirmed that the BAP is working. it's getting 12-13V at the output side normally, then 17-18V with the hobbs switch activated.
Old Sep 7, 2010 | 04:59 PM
robert miller's Avatar
robert miller
Default Ttt
For sure you will need a 2nd pump for the car when the car is in boost. Along with the boost a pump. I got my set up from Andy works great...
Old Sep 7, 2010 | 08:48 PM
HP_Addict's Avatar
HP_Addict
as long as you don't want more than 550 rwhp, drop in a Walbro 255 and call it done. If you have higher goals then go to a 2 pump system.
Old Sep 7, 2010 | 09:40 PM
spoolin7's Avatar
spoolin7
i don't think a 2nd pump is needed quite yet. i'm shooting for 550-600whp, so a 255 might just do the trick. i've always thought the stock pump with a BAP was enough for 600ish at the wheels. i don't think i've even seen 8psi and the pressure drop was insane. any good place to get a walbro 255hp from?
Old Sep 8, 2010 | 11:00 AM
HP_Addict's Avatar
HP_Addict
Check out Racetronix or LPE
Old Sep 8, 2010 | 03:26 PM
utryd2's Avatar
utryd2
I have a racetronix setup Im selling. It held 660rwhp at 60psi (fuel pressure) with a bap and 60lb injectors.
Pm me if interested.
Old Sep 8, 2010 | 07:00 PM
spoolin7's Avatar
spoolin7
those guys want too much money for a damn walbro
will do
Old Sep 12, 2010 | 09:40 PM
spoolin7's Avatar
spoolin7
changed the fuel filter and it appears to have helped a ton. it's now holding 58psi all the way to 6,500rpm, then dropping to about 50psi at 7,000rpm. amazing what a filter change can do
To another fuel pressure drop problem
