Tunnel Cover
Old Sep 25, 2010 | 09:39 PM
denscor's Avatar
denscor
Default Tunnel Cover
I have the 1/4 tunnel cover and when I was changing the oil I noticed that 5 of the bolts were missing so I replaced all the bolts with M6-1.0 X 30mm ones except one there was no thread insert in the hole. Will it be OK to just leave it alone? Or should I try to fix it?
Old Sep 26, 2010 | 11:44 AM
corvettebob1's Avatar
corvettebob1
I would fix it, GM didn't put any extra bolts in.
Old Sep 26, 2010 | 11:52 AM
HP_Addict's Avatar
HP_Addict
You had 5 missing, now you have 4 missing. The way I look at it is you are better off than before. I can't believe that 1 missing bolt will make a difference, since there are what 100 bolts in the tunnel cover.
Old Sep 26, 2010 | 02:54 PM
leo12's Avatar
leo12
Old Sep 26, 2010 | 03:27 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
You will be just fine. I always felt there was alittle overkill
with all the bolts for the tunnel plate.
Old Sep 26, 2010 | 05:47 PM
denscor's Avatar
denscor
I only have one missing now but the nut insert is gone. Plus I bought longer bolts because I have a thicker cover and replaced all the bolts.
Old Sep 27, 2010 | 02:52 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
One missing bolt on a tunnel plate isn't a big deal. You could probably run a tap through the missing one to fix the problem.
To Tunnel Cover
