Blown head gasket.
Old Oct 6, 2010 | 09:07 PM
396375's Avatar
396375
St. Jude Donor '08-'09
Default Blown head gasket.
I got my 9 second pass and on the next run my buddy drove and blew a head gasket.The gasket blew on #3 cylinder,blew the ground strap on #1 and torched the head between cylinders.My boost was 14#s,ARs were 1080-1100,94 octane,meth and a real safe tune.The weekend before the ARs hit 1250 for a split second and I got out of it.We dynoed the next day and everything seemed ok.4 passes later and it blew the gasket.I have ARP studs,LS9 gaskets on an iron block with 317 heads and 95# injectors.Car made 671RWHP.My fuel system is 2 Bosch 44s and the stock fuel system is intact.1 Bosch pump and the stock pump drive the car and the second pump joins in with a Hobbs switch.I know a lot of people don't like 2 pumps but I figured even if one pump went out the other pump and the stock pump should have been enough to hold things together at this power level.We'll be testing the pumps tomorrow and doing a leak down on the other bank.Plugs are TR6 and look fine except for the blown ground strap and #3 was coated grey from coolant.This is no biggie as i have done worse in the past.I just hate putting things back together without finding a problem.
Anyone have any ideas?
Old Oct 6, 2010 | 09:26 PM
TracyRR's Avatar
TracyRR
oh crap.... that sux... sorry to hear about that. Did you happen to check the plugs after you dyno'd? Just curious if it nipped the plug first as a warning.
Old Oct 6, 2010 | 09:28 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
try a non projected tip plug next time. make sure you didn't have any vacuum lines blow off that might have killed your meth system or fuel regulator (if you're boost referenced)
Old Oct 6, 2010 | 09:31 PM
Chris Stewart's Avatar
Chris Stewart
Aww that blows. Did it happen during a run or on the street? Banging on the rev limiter would make it happen pretty quick.
Old Oct 6, 2010 | 10:48 PM
Arun@CCP's Avatar
0Arun@CCP
Former Vendor
You need to back off your timing Ken. What you can get away with on the dyno and the track are 2 different animals.
Old Oct 7, 2010 | 11:59 AM
TracyRR's Avatar
TracyRR
ken, forgot to mention.... i have two LED lights that signal when the hob switch's for the meth and the second fuel pump are activated. Although this is not fool proof, at least it lets you know at a glance that the pumps have received 12 volts. I mounted them on the gauge pillar near the boost/afr gauges. Best of luck bro!
Old Oct 7, 2010 | 04:44 PM
396375's Avatar
396375
Thanks to everyone.I'll let you know if we find anything.
Take care.
Old Oct 7, 2010 | 05:01 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Bummer! 9 second pass was good to get
Let us know how the fix goes
Thanks,Matt
Old Oct 7, 2010 | 06:03 PM
tail_lights's Avatar
tail_lights
Sorry to hear about the gasket, here's to a quick fix!
Old Oct 7, 2010 | 06:34 PM
BLOWNBLUEZ06
your cylinder should have signature markings on the combustion chambers and pistons if it was caused by detonation. It might look like micro craters from aluminum spatter. Looking for spots on the other plugs with a good jewelers loop is a good idea too. You often won't see it without good magnification.
Old Oct 7, 2010 | 08:17 PM
396375's Avatar
396375
Ya.I'm still looking for my old Champion plug reader.
To Blown head gasket.
