Boost a pump
Old Oct 11, 2010 | 11:54 AM
jimish's Avatar
jimish
Default Boost a pump
I installed a Ken Belle boost a pump and it doesn't seem to be working correctly. Its supposed to start building voltage at 3.5 psi. At idle and slow cruising it is putting out 13.8 volts. The fuel pressure is anywhere between 61 and 67 psi. When first installed I was getting an a/f ratio of 10.5 off boost, and 9.5 on boost. We tuned the car (60# injectors) to get consistent 11.8, and next time I drove it your eyes would water if you stood behind it and it has no real power.
Does this seem right?
Old Oct 11, 2010 | 12:24 PM
zeevette's Avatar
zeevette
I was told by a tuner that the KB BAP is basically on/off. I don't know if it's supposed to modulate.
Old Oct 11, 2010 | 12:41 PM
black turbo c5's Avatar
black turbo c5
I think you might have some other issue's. I wouldn't think it would be a pump problem.
Old Oct 11, 2010 | 12:58 PM
jimish's Avatar
jimish
I realize I need to tune it to the right a/f ratios, but there is a dail, from 0 to 50%. At max, (50% of 12 volts) it should supply 18 volts. KB doesn't provide any instructions on how to adjust, and I am questioning them on that, the only hint is under a mustang supercharger section they list 20-25% for 9# of boost.
They provide a 3.5# hobbs switch, so at idle, no boost, it shouldn't be up around 66-67psi.
Old Oct 12, 2010 | 07:41 AM
clif's Avatar
clif
St. Jude Donor '09-'10
Don't waste your money with a BAP. Just buy a higher volume fuel pump, or even a dual fuel pump, like the RSI system. The BAP will just overdrive the motor coils on the pump motor and cause it to fail sooner.
Old Oct 12, 2010 | 03:18 PM
jimish's Avatar
jimish
If you go with a higher volume pump do you have to use a return regulaton instead of the factory filter/regulator.
Old Oct 12, 2010 | 03:22 PM
clif's Avatar
clif
I use a boost-referenced regulator with a new return line back to the tank.
To Boost a pump
