turbo questions?
hi guys im looking to place a front mount turbo system on my C5. the car has roughly 90k on it. any sugestions on what to do and do you think ill pop the motor with added turbo. also would a shot of nitros be the better way to go for HP?
thanks !
thanks !
Turbo is always the right answer. if you want a front mount single the only option i know of is the Hinson kit. There is like 4 threads on it that have good info. If you keep boost moderate the engine should be fine. With just a pump and injector upgrade i wouldn't go over 500rwhp.
if you want to save the motor, leave it alone.
If you want to stay "safe"...(biggest joke ever).... Keep it to low boost and live with the hp you get.
When youre ready to play hard, build it and boost it.
sounds good to me! where would i pick up the hinson kit any recomendations? at worst case this winter the car is gettin a cam but i would like to be pushin the same hp as my dads 07 z06 (well somewhat close to it anyway) totally different car i kow that but it never hurts to try to be different!! thanks guys !!
