Power?
Old Oct 18, 2010 | 04:25 PM
daws222000's Avatar
daws222000
Default Power?
Does anyone know which wire i can tap into that is constant WHILE CRANKING. Most wires will not have power while cranking, i need the one that does for my boost gauge so it 0s itself back properly. If it dont i will not get a accurate reading. Its a autometer dig boost /vac gauge. Thanks for any help Eric.
Old Oct 18, 2010 | 05:23 PM
Slow Z06's Avatar
Slow Z06
There is a 3wire pigtail down by the fusebox that is tapped off. one is constant, one is keyed the last is ground.
Old Oct 18, 2010 | 05:48 PM
daws222000's Avatar
daws222000
Thanks i will have to check that out. So it stays on during cranking? Every wire i check so far turns on then while cranking it goes off untill the car is started. Hopefully this works so i dont have to test a bunch more wires lol
Old Oct 19, 2010 | 05:11 PM
daws222000's Avatar
daws222000
Default Hot wire
Ok i found a pink wire under the dash keeps power while cranking. Gauge all hooked up and working.
To Power?
