Your guages look great. You need a home page with more photos of your car.
Another question: Is there a guage that can tell you amount of nitrous in bottle? I know the pressure can be fine with the bottle empty. I ask 'cause I'm only getting about 6 runs with a bottle. It's a PITA to run out at the track.
I don't think there is a gauge that will tell you how much nitrous left in the bottle. You can easily tell this by the psi when it's not heated. For example: When the bottle is full, the pressure should read somewhere ~1100psi unheated, after a few run it will drop down to ~900psi and so on.....
I would highly suggest an EGT guage. I run one on every forced induction/nitrous application I do. It's great insurance and will tell you more than the A/F meters that all of the guage companies sell. I think there may be a couple of independants building some linear A/F meters (ie. wide-band) that actually would do some good at a reasonable price. But in the meantime, an EGT and either a fuel pressure guage or a N2O pressure guage.
-Jeb Burnett
I had a triple pod made for A/F, Boost, Fuel Pressure.
They are bullet shaped (hard to see) but I will be replacing them with the new Cobalt ones when they come out.
-Jeff Nation
Man...It's looking good. So tell me where should I send my $$$ to? :D
-Tuan
The guys that did mine do excellent work. EarMark Custom Sound and audio did those pods. Talk to Nick. Their number is on my "stereo install" site.
goto http://www.chantalray.homestead.com/z06.html and click "stereo install" for their number. :cheers:
