Belt chart
Old Nov 5, 2010 | 05:05 PM
Blow Torch's Avatar
Blow Torch
Default Belt chart
Sorry to have to ask guys, but does someone have a link to the Pro-charger belt length chart? I am getting just a LITTLE bit of slip, and I am at the end of my "adjustment range" Need to try a shorter belt.
Old Nov 5, 2010 | 05:14 PM
Jeremy@HOB's Avatar
0Jeremy@HOB
Former Vendor
What size belt are you running now?
Old Nov 5, 2010 | 06:24 PM
FRCTony's Avatar
FRCTony
Stage II Brackets
5.00" Pulley = 90.8"
4.75" Pulley = 90.5"
4.63" Pulley = 90.5"
4.50" Pulley = 90.0"
4.38" Pulley = 90.0"
4.25" Pulley = 90.0"
4.10" Pulley = 89.5"
4.00" Pulley = 89.5"
3.85" Pulley = 88.8"
3.70" Pulley = 88.8"
3.60" Pulley = 88.8"
3.50" Pulley = 88.8"
3.40" Pulley = 88.8"
3.20" Pulley = 88.8"
3.10" Pulley = 88.8"
3.00" Pulley = 88.8"
Old Nov 5, 2010 | 07:19 PM
Blow Torch's Avatar
Blow Torch
I believe it is the 88.8. I have a 3.7" pulley, and I have only had it on for approx. 4000 miles, so it shouldn't be stretched.
Seems odd that the same belt would fit such a large range.
Old Nov 5, 2010 | 07:34 PM
FRCTony's Avatar
FRCTony
Time for the OD damper
How much boost at what RPM are you getting with 3.70?
Old Nov 5, 2010 | 07:47 PM
Gitusum's Avatar
Gitusum
anyone know what belt i would need for a 4.25 pulley and a od balancer pulley on the car?
Old Nov 5, 2010 | 08:01 PM
Blow Torch's Avatar
Blow Torch
I'm around 10 psi at 6100rpm
To Belt chart
