O2 sender location
Old Nov 17, 2010 | 01:01 PM
jimish's Avatar
jimish
Default O2 sender location
Purchased a LM2 wideband reader and the instructions say to install downstream of the turbo. Would this count if I have a STS style rear mount turbo. The only pipe after the turbo is a 2' long, 3" pipe. Ive done my previous tuning with the O2 about halfway from the manifold to the turbo.
Old Nov 17, 2010 | 05:13 PM
TracyRR's Avatar
TracyRR
i installed my wideband a few inches after the turbo on my sts system.... not much room to do anything else after the turbo. I think i have read that the afr will show a little leaner than actual with the wideband located that far down from the engine. Someone correct me if i'm wrong. Best of luck
Old Nov 18, 2010 | 08:34 AM
jimish's Avatar
jimish
Since most tuning is done with a clamp on sender in the end of the tailpipe, I guess just past the turbo will work. Its probably 18" from the end.
To O2 sender location
