I'm looking for the Coil Trigger wire for RPM feed to connect a window switch. Is this the wire connected to each coil labled IGN CTRL in the 2004 Corvette service Manual?
Thx, Jeff Serebrin
Theodore Al
Thx, Jeff Serebrin
Theodore Al
The coil trigger wire is the wire that is a different color on each connector on the coils. However the window switch will not work reliably unless you go directly to the tach output off the ECU.
Thx. I'll look at the wiring diagram tonight for the ECU. The ECU is behind the passenger side kick panel?
One other question, is the green wire in the TPS harness the wire that sends the position of the blade to the ECU? Looks like it to me on the wiring diagram.
