Winter Projects
Old Dec 30, 2010 | 12:50 PM
  #201
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Originally Posted by Milan
Can you take a closer pic of your 45* fitting? It doesn't seem possible on my motor to do that.
Since my BBK rails also feed from the side, I'm going to run a crossover in the front and then run the rear pass side rail into my FPR
Here are a couple pics:
Rear Passenger side rail w/45* fitting:
Rear Drivers side rail w/90* fitting;
Old Dec 30, 2010 | 02:43 PM
  #202
Milan's Avatar
Milan
How much clearance is there between that 90* fitting and the firewall?
Old Dec 30, 2010 | 02:47 PM
  #203
Corvette-Chris
St. Jude Donor '08
Not much at all
Old Dec 30, 2010 | 02:57 PM
  #204
Its Bruce's Avatar
Its Bruce
A 90° -AN o-ring to -AN fitting should give you a bit more room.
Old Dec 30, 2010 | 03:08 PM
  #205
Corvette-Chris
St. Jude Donor '08
Aeromotive was trying to sell me this
http://www.shopatron.com/products/pr...AER15665/415.0
Bit I didn't need any more room. If it fits, it fits
Plus, I have a -10AN breather line back there.
Old Dec 30, 2010 | 06:37 PM
  #206
Milan's Avatar
Milan
Are you feeding your rails from the center? If so can you take a picture of that for me at the rail? Did you run a new fuel line?
Old Dec 30, 2010 | 07:03 PM
  #207
Corvette-Chris
St. Jude Donor '08
You can see it in this pic. It is the silver fitting going up into the rail. I didn't run a new feed line. I wasn't having any fueling issues whatsoever so Ill keep the feed line until I upgrade turbos.
Old Dec 30, 2010 | 07:08 PM
  #208
Corvette-Chris
St. Jude Donor '08
BTW, I got the car on the ground and drove it. No OIL leaks so far, which I am happy to report. I only got to about 5psi but I would hope the (2) -10AN lines would do a good enough job of venting the crankcase.
Still have a TINY leak from the same spot of the turbine housing / exhaust flange that was there before, but it is significantly reduced. I would assume that the flange is still a little warped, despite me tediously using a file to make it true. Something that small I can live with, for now.
All is well and I hope to have some footage of me taking down an A&A Vortech C6 this weekend On a closed course, obviously.
Old Dec 30, 2010 | 08:29 PM
  #209
Milan's Avatar
Milan
I'm going to try to draw a picture in paint and see if you can tell me if that will work with the Aeromotive rails.
Also are the threaded ends on the rails -8an?
Old Dec 30, 2010 | 08:44 PM
  #210
Corvette-Chris
St. Jude Donor '08
Ok, I'll take a look at it.
Yes, all ports are -8AN
Old Dec 30, 2010 | 08:51 PM
  #211
Milan's Avatar
Milan
Let me know if this makes sense.
Old Dec 30, 2010 | 09:11 PM
  #212
Corvette-Chris
St. Jude Donor '08
Milan, that looks like it will be just fine.
What you may think about doing is using a T in the rear of the drivers side rail. When I spoke with Aeromotive about the center feeding point, they had concern with the rear 2 injectors on that side and being out of the natural flow of fuel. This is the reason why I went ahead and added a rear crossover as well.
If you use a T on the drivers rail, you could have the cross over in the rear and have a port to run to your FPR.
Old Dec 30, 2010 | 09:31 PM
  #213
Milan's Avatar
Milan
Okay so what if I run the crossover in the rear, use the opposite two ends for the feed from that special fitting and then run a line from the middle into my FPR, do you think that would make sense?
Old Dec 30, 2010 | 10:28 PM
  #214
MyEBc5Z's Avatar
MyEBc5Z
Im gonna be installing an A&A kit with a P1SC, A&A blower cam, stage 2 meth kit, yella terra rocker arms, mt et streets, and new torque tube couplers on my 02 z06! This is going to be a fun spring/summer!! There arent any other 18 year olds around here who will have a faster car!
Old Dec 31, 2010 | 10:42 AM
  #215
clif's Avatar
clif
St. Jude Donor '09-'10
Here is how I built my fuel system:
Old Dec 31, 2010 | 12:08 PM
  #216
corvette8189's Avatar
corvette8189
send me footage
Old Dec 31, 2010 | 02:11 PM
  #217
Slow Z06's Avatar
Slow Z06
What he said
To Winter Projects
Old Dec 31, 2010 | 02:16 PM
  #218
Corvette-Chris
St. Jude Donor '08
Originally Posted by corvette8189
send me footage
It might have to wait, as I seem to have caught the flu. This **** sucks....
Old Dec 31, 2010 | 02:20 PM
  #219
Slow Z06's Avatar
Slow Z06
Well that sucks ****
Old Dec 31, 2010 | 03:51 PM
  #220
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
meow?!?!
