Meth and boost?
Old Nov 27, 2010 | 11:21 AM
Arun@CCP's Avatar
0Arun@CCP
Former Vendor
Originally Posted by PhilsZ51
LQ9, Iron, Callie compstar everything, CP Pistons -15.00cc dish 4.030" bore size 1.200", CH piston set includes Nitrided steel piston ring set, napier 2nd, took that off build sheet. All ARP hardware.
What stroke is the motor?
Old Nov 27, 2010 | 12:47 PM
PhilsZ51's Avatar
PhilsZ51
3.825" Stroke. I think that is what you are looking for, but if need be, I can post the build sheet.
Old Nov 27, 2010 | 12:59 PM
Arun@CCP's Avatar
0Arun@CCP
Former Vendor
I'm getting a CR of 9.8-that's with .051 thou LS2 gasket. Why not just ditch the LS6 heads and get a CNC 317 head-you'll drop the compression and pick up power from the extra flow.
We picked up 50 rwhp by adding a CNC 317 head over a stock 241 head on a 346 without turning the boost up. It lowered the compression making it more pump gas friendly but picked up power by being more effecient.
Old Nov 27, 2010 | 01:00 PM
PhilsZ51's Avatar
PhilsZ51
ls9 gaskets, not sure if that makes a difference. I was thinking of putting 317s on there, but I just got it back together and don't feel like ripping the heads off again.
Old Nov 27, 2010 | 01:43 PM
Arun@CCP's Avatar
0Arun@CCP
Former Vendor
Just tune it 11.1 on the dyno then do a pull in 5th on the hwy to make sure she's stills there with the extra airflow. Probably won't be able to get away with more than than 16 degrees total timing. I'd pull out another 2 from whatever she peaks out at on the dyno to be safe.
Set up the knock tables on the sensitive side.
Old Nov 27, 2010 | 03:54 PM
PhilsZ51's Avatar
PhilsZ51
I think I am going to toss a restrictor in to limit the boost to around 15 lbs. For the fuel, I think I am going to use 91+torco and meth.
Old Nov 27, 2010 | 04:11 PM
jobberone's Avatar
jobberone
jobberone
With a proper tune you should be ok with 91 octane and meth if you're running 15lbs. You don't need any additives.
Old Nov 28, 2010 | 08:45 PM
PhilsZ51's Avatar
PhilsZ51
What if I switched to E85?
Old Nov 28, 2010 | 09:09 PM
jobberone's Avatar
jobberone
jobberone
I thought about doing that but I can't get it readily enough where I am. Also you have to have the injectors to do that. I'm at a 50% duty cycle with my injectors so I was ok but you need to flow a good deal more with E85. Will your injectors flow that much? It will boost your octane though. Again you don't need more octane than the 91 if you limit your boost.
