Rocker arm recommendations
Old Nov 25, 2010 | 04:26 PM
jobberone's Avatar
jobberone
jobberone
Default Rocker arm recommendations
I'm replacing my heads on my 347 TT setup. Going to AFR 230s which I can't find out much on. First has anyone any experience with the AFR 230 heads? Second I need to know what rocker arm to use. I can get a better price on Jesel rockers but I've heard they weren't best for my app. My only other alternatives IMO are the Comp cam 1500 or the same T&D rockers. Something about shims and the Jesel rockers with the AFR. Some techs: lift 620s. rev limit 7000. shift point 6800. Springs I don't know height yet as they are supposedly going to be custom springs. Probably 1.74 or so. Seat pressures in the 180 range intake with opening pressure about 540. Boost limit 20-22. Rockers 1.7 ratio. Normal hyd cam bearings. Caddy lifters.
Old Nov 25, 2010 | 06:06 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
On my TFS 215's I am using:
Harland Sharp RR's 1.7
There are also Yella terra RR's that can be used and many have had good success with them
I talked with TFS when I got my heads and went with their recomendation, you could do the same with AFR and see what they recommend.
Thanks,Matt
Old Nov 25, 2010 | 06:24 PM
jobberone's Avatar
jobberone
jobberone
Would you recommend them over the Jesel or T&D rockers?
Old Nov 25, 2010 | 06:33 PM
madmatt9471
Jesel are good and I am not real familiar with the T&D rockers -
Others will chime in and I wouldn't hesitate to see which AFR recommends
I do know that I have had great success with my HS RR's. I've known others who have run them happily with AFR's
Thanks,Matt
Old Nov 25, 2010 | 07:12 PM
jobberone's Avatar
jobberone
jobberone
Can I ask you how much you paid for them?
Old Nov 25, 2010 | 07:17 PM
madmatt9471
Looking at around $380
http://www.jegs.com/i/Harland%20Shar...0002/-1?CT=999
Harland Sharp:
http://www.harlandsharp.com/ls1.htm
You can search the part number more and see if there is a better deal.
Thanks,Matt
Old Nov 25, 2010 | 07:21 PM
jobberone's Avatar
jobberone
jobberone
Thanks for all your help. I'll talk to my tuner and AFR next week.
Old Nov 25, 2010 | 10:36 PM
robert miller's Avatar
robert miller
Thanks,Matt
The big diff in the two is that the T&D has a small hole on top of the rocker that help oiling better than the other...
Old Nov 26, 2010 | 10:43 AM
madmatt9471
Well, there you go!
Greetings Robert - Going to the LA Auto Show in a while with the family
Good to hear from you
I am taking the Vette out next saturday the 4th of Dec to possibly hit the 9's!
I was not too familiar with the T&D's, but that is good info on them. I'm sure it'll help him out
Have a good day and "corvettesforfun" let us know what you decide on
Thanks,Matt
Old Nov 26, 2010 | 11:51 AM
robert miller
Well, there you go!
Thanks,Matt
Same here matt hope everone is doing good. Have a good time at the show. Man that car is getting faster and faster.
Old Nov 26, 2010 | 01:11 PM
heavymetals's Avatar
heavymetals
I use the Comp Cams #1500 on my V.
WHOO HOO!
You will need a 1/2" spacer (Jegs) to get them to fit without hitting the valve cover.
Old Nov 26, 2010 | 01:33 PM
robert miller
WHOO HOO!
you are correct.
Old Nov 26, 2010 | 01:55 PM
heavymetals
Here is a peek:
(note, you also have to "open up" the push rod holes to keep the push rods from rubbing)
Old Nov 26, 2010 | 04:31 PM
Will at RSI's Avatar
0Will at RSI
Former Vendor
Shoot me a PM or email for Black Friday pricing on all Comp or Jesel Products.
Old Nov 26, 2010 | 06:35 PM
leo12's Avatar
leo12
Stay away from H. S (junk) ask any good builder they will tell you the same.
jessel is the way to go if you want to spend over seven bills, or for three bills you can get the next best rockers, Yella Terra altralites shaft mount.
Old Nov 26, 2010 | 07:19 PM
jobberone's Avatar
jobberone
jobberone
Where can I get Jesel rockers for $700?
Old Nov 28, 2010 | 03:46 PM
jobberone's Avatar
jobberone
jobberone
Ttt
To Rocker arm recommendations
Old Nov 29, 2010 | 04:50 PM
jobberone's Avatar
jobberone
jobberone
I'm being pushed to the yella terra rockers.
Old Nov 29, 2010 | 11:00 PM
jobberone's Avatar
jobberone
jobberone
I'm going to go with the YT rockers unless someone talks me into the T&D rockers. I think the Comp Cam 1500 are the same as the T&D. I do think I will need taller spacers for the T&D rockers and maybe nonstock valve covers. Is that true?
Old Nov 30, 2010 | 01:06 AM
heavymetals
You can use the stock valve cover(s) with the Comp Cams 1500, but you may have to Dremel out every boss and baffle (I did).
I got a 1/2" spacer from Jeg's to lift them up.
They work bitchin.
