IAT Relocation
Old Dec 9, 2010 | 06:16 PM
TT Z06's Avatar
TT Z06
Default IAT Relocation
Did this during my motor rebuild. Its cheap and easy to do. Drill with 37/64 bit and tap with 5/8 tap.
Old Dec 9, 2010 | 08:12 PM
joshtownsend's Avatar
joshtownsend
you could have at least put it in straight j hole!!!! i would have done it for you..
Old Dec 9, 2010 | 09:02 PM
TT Z06's Avatar
TT Z06
the thread contact is better since the neck is beveled.
Old Dec 9, 2010 | 09:30 PM
joshtownsend
just admit that nothing about you is straight!! hahaha The reason you put it straight is because of air flow restriction... I'll take a picture of mine and show you..
And just put red lockti on it.. its works like a champ
Old Dec 9, 2010 | 10:48 PM
Its Bruce's Avatar
Its Bruce
I've read that this works with a small modification to the 5 pin connector (dremmel to remove lip):
http://www.casperselectronics.com/st...oducts_id=1108
Old Dec 10, 2010 | 03:27 AM
joshtownsend
You can buy the pig tail form autozone or anywhere else for like $3, cut your 2 wires, and solder it on... that's what i did.
Old Dec 10, 2010 | 01:09 PM
miami993c297's Avatar
miami993c297
Inside the FAST 90 on my engine:
Christian
Old Dec 12, 2010 | 12:06 PM
corvettebob1's Avatar
corvettebob1
Christian
Anybody have a brand name and P/N for this sensor?
Old Dec 13, 2010 | 01:55 PM
corvettebob1
Anyone have a P/N?
Old Dec 13, 2010 | 01:59 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
I want to say that I have read that the brass sensor comes off the old Chevy Cyclone trucks. You may try google-ing it and see what you come up with.
Old Dec 13, 2010 | 05:07 PM
TT Z06's Avatar
TT Z06
I think I got it from a mid 90s camaro. dont remember a PN
Old Dec 13, 2010 | 10:42 PM
joshtownsend
you are all a bunch of slackers..but i love you anyways!!!
25036751 AC Delco IAT Sensor
12102620 AC Delco Wire Pigtail
http://www.pe-ltd.com/Downloads/air_temp.pdf
The screw in GM IAT sensor GM#25036751 or most parts stores carry Wells SU127.
The IAT service harness GM#12102620 or Delco #PT307 at your local parts store. You should be able to take that info to any autoparts store and cross reference it to something on the shelf.
For the record, i used the wells and no issues at all.
Old Dec 13, 2010 | 10:55 PM
Its Bruce's Avatar
Its Bruce
To add to that:
From further reading, the purple and tan wires are the IAT.
Old Dec 14, 2010 | 10:25 AM
corvettebob1
Old May 2, 2013 | 05:18 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
To add to the list of part#'s, here's the ones that I use.
Borg Warner Part number WT382 same as GM 213-190 or 25036751
I choose this sensor because a 3/8 NPT bung can be welded in and this sensor screwed in.
The pigtail is the same as the one for the plastic sensor that uses the grommet, Borg Warner PT778 at Oreilly's or Wells SU107 at AutoZone or TS5100 at NAPA
These parts came from earlier F-bodies like 97, or a 95 ZR1.
To IAT Relocation
