Blower cam question...
Old Dec 12, 2010 | 11:59 AM
JJ 86's Avatar
JJ 86
Default Blower cam question...
I want to add a supercharger in the near future. I'm curious as to if anyone here has had experience running TSP 228R cam with a blower? The cam specs are 228/228 .588 .588 on a 112. How well will this cam work with FI?
Old Dec 12, 2010 | 01:21 PM
ysb02's Avatar
ysb02
I was planning on installing a .592/.612 230/244 115 LSA cam this spring before adding a blower. I may get something with more duration though.
Old Dec 12, 2010 | 01:25 PM
corvettebob1's Avatar
corvettebob1
You'll be fine, I'm running a 224/230 .581/.592 on 112+2 and I love it.
With a stalled A4 I made +600rwhp with an open converter.
Old Dec 12, 2010 | 04:12 PM
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
I removed a 228r for a custom cam from Eastcoast Performance. I wanted to get every bit of power of my setup.
Old Dec 12, 2010 | 04:49 PM
jobberone's Avatar
jobberone
jobberone
It's not always easy to find the perfect cam for a setup. You can get in the ballpark. Your cam is conservative but not a lot. You will find a lot more power with heads, TB, intake and headers IMO esp heads.
Old Dec 12, 2010 | 06:59 PM
easyvette's Avatar
easyvette
You can do a million different searches on cams over here. There are a ton of people running cams under the 230`s/.600 mark... FYI alot of those people are making gobbs of HP.. Just remember one simple fact. A good N/A cam will make lots of power with a blower behind it IMHO.... I am not a big fan of the 110/112LSA I like a 115 just for idle purposes and thats just my prefference...
Old Dec 12, 2010 | 09:45 PM
HotRod68Camaro's Avatar
HotRod68Camaro
When i was doing my procharger install, Arun recommended trying out my MS4. It worked out great.
Old Dec 12, 2010 | 10:54 PM
jobberone's Avatar
jobberone
jobberone
It's more the heads than the cam. A good cam with a not so wonderful head is meah. A decent cam with a great head means optimum power.
Old Dec 13, 2010 | 01:31 AM
ZOHSIX's Avatar
ZOHSIX
I am very curious as to how this helped the OP at all??
Old Dec 13, 2010 | 01:28 PM
Vette310's Avatar
Vette310
Bump.
Old Dec 13, 2010 | 02:00 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
We feel we have the best blower cams here. Not only do the cams drive very well, they dyno well and run well at the track too. Any questions at all just let us know..
Old Dec 13, 2010 | 02:01 PM
Drewstein's Avatar
Drewstein
It'll work in the car but is your goal for it just to work?
Do you want a max power cam, a torque producing cam or what?
Think about what your goal is first and post that.
Old Dec 13, 2010 | 02:53 PM
Arun@CCP's Avatar
0Arun@CCP
Former Vendor
If your running just a stock bottom end and that cam is already there then I would just leave it. When your ready to forge it then I would swap the cam out for something designed for boost.
FWIW-we ran lots' of single pattern cams back in the Mustang days-even with the weak E7TE exhaust ports we still ran 9's with a little S-Trim.
Old Dec 13, 2010 | 06:01 PM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
I installed a A&A V2 Superchager Kit for a customer of mine and he had a 1999 C5 A4. The previous mods were TSP 220 Camshaft on a 114 LSA, Stage 1 LS6 Heads, Kooks Longtube Headers, Stock Trans and Stock Converter. The original dyno test was 380 rwhp. After the A&A kit, the C5 put down 573 rwhp and cut it off at 6000 rpm. If I would have ran it out to 6500 rpm, it should have made 600 rwhp.
To Blower cam question...
